[GRASS-dev] [GRASS GIS] #1430: Buffer overrun in vector/diglib dig__fread_port_L with big-endian negative values on LP64 systems
GRASS GIS trac at osgeo.org
Tue Aug 30 22:24:50 EDT 2011
 Reporter:  rroliver                         |       Owner:  grass-dev@…
     Type:  defect                           |      Status:  new
 Priority:  normal                           |   Milestone:
Component:  Vector                           |     Version:  svn-trunk
 Keywords:  diglib portable LP64 big-endian  |    Platform:  Unspecified
      Cpu:  All                              |
 The code in dig__fread_port_L is broken for handling big endian negative
 numbers on systems where sizeof(long) != PORT_LONG.
 Presently the code fails to negate the value and will write 4 bytes past
 the end of the buffer.
 Problem exists for all grass versions through to trunk...
 Patch attached (patch against 6.4.1)
Ticket URL: <http://trac.osgeo.org/grass/ticket/1430>
