[GRASS-dev] [GRASS GIS] #1431: r.sun segfault in mode 2
GRASS GIS trac at osgeo.org
Wed Aug 31 03:59:24 EDT 2011
 Reporter:  neteler  |       Owner:  grass-dev@…
     Type:  defect   |      Status:  new
 Priority:  normal   |   Milestone:  6.4.2
Component:  Raster   |     Version:  svn-releasebranch64
 Keywords:           |    Platform:  Linux
      Cpu:  x86-64   |
 With the NC data set, this crashes:
 GRASS 6.4.2svn (nc_spm_08):~ > g.region rast=elevation
 GRASS 6.4.2svn (nc_spm_08):~ > r.sun elevin=elevation aspin=aspect
 slopein=slope lat=36.107 day=75 beam_rad=b_rad.075 diff_rad=d_rad.075
 refl_rad=r_rad.075
 Mode 2: integrated daily irradiation for a given day of the year
 Segmentation fault
 Debugging output which looks like bad initialization:
 GRASS 6.4.2svn (nc_spm_08):~ > gdb r.sun
 GNU gdb (GDB) 7.1-1mdv2010.1 (Mandriva Linux release 2010.1)
 (gdb) r elevin=elevation aspin=aspect slopein=slope lat=36.107 day=75
 beam_rad=b_rad.075 diff_rad=d_rad.075 refl_rad=r_rad.075
 Starting program: /home/neteler/grass64/dist.x86_64-unknown-linux-
 gnu/bin/r.sun elevin=elevation aspin=aspect slopein=slope lat=36.107
 day=75 beam_rad=b_rad.075 diff_rad=d_rad.075 refl_rad=r_rad.075
 [Thread debugging using libthread_db enabled]
    0%
 Program received signal SIGSEGV, Segmentation fault.
 pj_transform (srcdefn=0x0, dstdefn=0x0, point_count=1, point_offset=0,
 x=0x7fffffffd0e0, y=0x7fffffffd0d8,
     z=0x7fffffffd0d0) at pj_transform.c:98
 98          if( srcdefn->is_geocent )
 (gdb) bt full
 #0  pj_transform (srcdefn=0x0, dstdefn=0x0, point_count=1, point_offset=0,
         i = <value optimized out>
 #1  0x00007ffff7bd9b26 in pj_do_proj (x=0x7fffffffd268, y=0x7fffffffd270,
 info_in=0x60d760, info_out=0x60d7e0)
     at do_proj.c:100
         ok = 1092827616
         u = 0
         v = 0
         h = 0
 #2  0x00000000004080e1 in calculate (singleSlope=1.2135880960744616e-311,
 singleAspect=3.6562339989189768e-319,
     singleAlbedo=0.20000000000000001, singleLinke=3, gridGeom=...) at
 main.c:1865
         i = 1
         j = 1
         l = 1350
         someRadiation = 1
         numRows = 1350
         arrayOffset = 1
         lum = 6.9533488366228911e-310
         q1 = 3.1829936871890069e-311
         dayRad = 3.1514668911888089e-317
         latid_l = 6.9533558072950894e-310
         cos_u = 2.0779926761062822e-317
         cos_v = 6.9533558073061565e-310
         sin_u = 6.953349070413816e-310
         sin_v = 0
         sin_phi_l = 0
         tan_lam_l = 0
         zmax = 156.32986450195312
         longitTime = 0
         locTimeOffset = 1.4821969375237396e-323
         latitude = 215010
         longitude = 630010
         coslat = 630000
         sunGeom = {lum_C11 = 2.0969134140794186e-317, lum_C13 =
 6.3691388397870058e-314,
           lum_C22 = 6.9533488366228911e-310, lum_C31 =
 6.9533491751815725e-310, lum_C33 = 6.9533558072603072e-310,
           sunrise_time = 2.1219957904712067e-314, sunset_time =
           timeAngle = 4.9406564584124654e-324, sindecl =
 0.030294190998040194, cosdecl = 0.99954102566716807}
         sunVarGeom = {isShadow = -11720, z_orig = 127.38738250732422, zmax
 = 156.32986450195312, zp = 127.38738250732422,
           solarAltitude = 0, sinSolarAltitude = 0, tanSolarAltitude =
 6.9533488354035371e-310,
           solarAzimuth = 6.9533490691820115e-310, sunAzimuthAngle =
 6.9531436082559572e-310, stepsinangle = 0,
           stepcosangle = 0}
         sunSlopeGeom = {longit_l = 6.9533558072535879e-310, lum_C31_l =
 2.1219957909652723e-314,
           lum_C33_l = 6.9533488359529381e-310, slope =
 0.075450657666172191, aspect = 5.0632796287624782}
         sunRadVar = {cbh = 1, cdh = 1, linke = 3, G_norm_extra =
 1381.7904736323146, alb = 0.20000000000000001}
 #3  0x000000000040488b in main (argc=9, argv=0x7fffffffd638) at main.c:768
         singleSlope = 1.2135880960744616e-311
         singleAspect = 3.6562339989189768e-319
         singleAlbedo = 0.20000000000000001
         singleLinke = 3
         module = 0x7ffff7bd4f40
         parm = {elevin = 0x7ffff7bd4ea0, aspin = 0x613da0, aspect =
 0x613e70, slopein = 0x613f40, slope = 0x614010,
           linkein = 0x6140e0, lin = 0x6141b0, albedo = 0x614280, longin =
 0x6145c0, alb = 0x614350, latin = 0x614420,
           lat = 0x6144f0, coefbh = 0x614690, coefdh = 0x614760, incidout =
 0x6149d0, beam_rad = 0x614aa0,
           insol_time = 0x614b70, diff_rad = 0x614c40, refl_rad = 0x614d10,
 glob_rad = 0x614de0, day = 0x614eb0,
 ---Type <return> to continue, or q <return> to quit---
           step = 0x614f80, declin = 0x615050, ltime = 0x615120, dist =
 0x6151f0, horizon = 0x614830,
           horizonstep = 0x614900, numPartitions = 0x6152c0, civilTime =
 0x615390}
         flag = {shade = 0x7ffff7bd4e60, saveMemory = 0x615490}
         gridGeom = {xp = 6.9531436082559572e-310, yp = 0, xx0 =
 6.9533491762080433e-310, yy0 = 0,
           xg0 = 6.9533491624931762e-310, yg0 = 6.9533491654678467e-310,
 stepx = 10, stepy = 10, deltx = 15000,
           delty = 13500, stepxy = 10, sinlat = 6.9533558072840223e-310,
 coslat = 6.9533558072852081e-310}
Ticket URL: <http://trac.osgeo.org/grass/ticket/1431>
