[GRASS-dev] Error compiling the latest grass7svn
Thu Jun 9 03:03:50 EDT 2011
Pierre Roudier wrote:
> I just encountered the following error while compiling the last svn up
> of grass_trunk:
> In file /usr/local/src/grass7-svn/grass_trunk/dist.x86_64-unknown-linux-gnu/include/grass/gprojects.h,
> couldn't find ogr_srs_api.h
When posting compilation errors, it helps if you post the compilation
command as well as the error message.
> I turned ogr_srs_api.h to gdal/ogr_srs_api.h and it did pass the error
> and compiled.
This looks like something has changed with your GDAL installation.
