[GRASS-dev] [GRASS GIS] #1286: clean_temp can not be called before LCATION_NAME is set
GRASS GIS trac at osgeo.org
Tue Mar 1 06:09:59 EST 2011
 Reporter:  marisn       |       Owner:  grass-dev@…
     Type:  defect       |      Status:  new
 Priority:  blocker      |   Milestone:  6.4.1
Component:  Startup      |     Version:  6.4.1 RCs
 Keywords:               |    Platform:  MSWindows Vista
      Cpu:  Unspecified  |
 clean_temp uses G_gisinit(argv[0]) and thus should never be run outside of
 GRASS session, still it is used in init.bat before location name is set on
 windows and is failing with error: "G_getenv(): Variable LOCATION_NAME not
 set" Calling G_getenv on non-existing variable is an fatal error and thus
 brings down whole startup procedure.
 There are two possible solutions for this problem:
  * do not use clean_temp in init.bat
  * do not use G_gisinit() in clean_temp
Ticket URL: <http://trac.osgeo.org/grass/ticket/1286>
