[GRASS-dev] Re: [GRASS GIS] #1286: clean_temp can not be called before LCATION_NAME is set
GRASS GIS trac at osgeo.org
Tue Mar 1 14:51:45 EST 2011
 Reporter:  marisn       |       Owner:  grass-dev@…
     Type:  defect       |      Status:  new
 Priority:  blocker      |   Milestone:  6.4.1
Component:  Startup      |     Version:  6.4.1 RCs
 Keywords:               |    Platform:  MSWindows Vista
      Cpu:  Unspecified  |
Comment(by glynn):
 Replying to [ticket:1286 marisn]:
 > There are two possible solutions for this problem:
   * do not use clean_temp in init.bat
   * do not use G_gisinit() in clean_temp
 There is only one possible solution: the first one. The purpose of
 clean_temp is to clean up the mapset's temp directory
 (<database>/<location>/<mapset>/.tmp/<hostname>). If you don't have a
 database/location/mapset set, clean_temp can't work.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1286#comment:1>
