[GRASS-dev] Re: [GRASS GIS] #1301: wingrass: db.in.ogr fails to load .csv file
GRASS GIS trac at osgeo.org
Tue Mar 8 23:52:56 EST 2011
 Reporter:  morrisxs09  |       Owner:  grass-dev@…
     Type:  defect      |      Status:  new
 Priority:  normal      |   Milestone:  6.4.1
Component:  Database    |     Version:  svn-releasebranch64
 Keywords:  wingrass    |    Platform:  MSWindows XP
      Cpu:  x86-32      |
Changes (by hamish):
  * keywords:  => wingrass
Comment:
 "\" is used as the quoting character, this is often used to deal with path
 names with spaces, instead of breaking the path into two command line args
 (otherwise it would not know where dsn= ended and the next option [in this
 case one called output=] began). to get a literal "\" you either need to
 quote it (with itself) like "\\" or put the whole thing in "double
 quotes".
 for example: `dir=C:\\Program\ Files\\` or `dir="C:\Program Files\"
 So the computer sees "D:\Data" with a literal "D", and it becomes
 translated to "D:Data".
 Solution: always "quote" filenames, or use the "/" workaround.
  db.in.ogr dsn="D:\Data\ProjData\GRASS_db\dmp_lg.csv" output=test
 Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1301#comment:1>
