[GRASS-dev] Re: [GRASS GIS] #1301: wingrass: db.in.ogr fails to load .csv file
GRASS GIS trac at osgeo.org
Wed Mar 9 00:21:12 EST 2011
 Reporter:  morrisxs09  |       Owner:  grass-dev@…
     Type:  defect      |      Status:  new
 Priority:  normal      |   Milestone:  6.4.1
Component:  wxGUI       |     Version:  svn-releasebranch64
 Keywords:  wingrass    |    Platform:  MSWindows XP
      Cpu:  x86-32      |
Changes (by hamish):
  * component:  Database => wxGUI
Comment:
 Replying to [comment:2 morrisxs09]:
 > Are you suggesting quotes have to be added after the "Table
 > file to be imported or DB connection string" field is populated?
 try it. if that makes it work, then yes.
 if so, the root of the problem is that the path strings are not getting
 quoted automatically by the file-picker?
 Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1301#comment:3>
