[GRASS-dev] Re: [GRASS GIS] #1139: v.report has a problem (only via OSGEO4W package)
GRASS GIS trac at osgeo.org
Wed Mar 9 16:55:32 EST 2011
 Reporter:  naokiueda           |       Owner:  grass-dev@…
     Type:  defect              |      Status:  new
 Priority:  normal              |   Milestone:  6.4.0
Component:  Vector              |     Version:  6.4.0 RCs
 Keywords:  wingrass, v.report  |    Platform:  Unspecified
      Cpu:  Unspecified         |
Comment(by hellik):
 Replying to [ticket:1139 naokiueda]:
 > with version GRASS 6.4.0svn
 > v.report does not work.
 > when run, it cause following error.
 > "Input file specified two times.
 > There is a table connected to input vector map '*****', but there are no
 categories present in the key column '***'. Consider using v.to.db ro
 correct this."
 > Malfunctioning on GRASS 6.4.0.SNV included in OSGEO4W version on
 windows7.
 > g.version -r returned following.
 > RASS 6.4.0svn (2010)
 > Revision: 37101
 > Date: 2009-05-10 13:35:38 +0200 (Sun, 10 May 2009)
 > Note that it working normally on single version of GRASS with same
 version. (Download from Web and install as a independent application
 istead of installed as a OSGEO4W package)
 > Working version also returned same version, but different time stamp.
 > Revision: 37101
 > Date: 2009-05-10 04:3538 -0700 (Sun, 10 May 2009)
 still an issue? closing the ticket?
Ticket URL: <http://trac.osgeo.org/grass/ticket/1139#comment:3>
