[GRASS-dev] parsing file paths in GRASS Scripts- Windows OS
katrin eggert katrineggert1980 at gmail.com
Mon Mar 14 13:35:33 EDT 2011
Hi There
I talked with Helmut, since he is an Win-GRASS expert user, and we have done
this test with WinGRASS (Bash Scripts):
r.out.xyz input=<whatever but it can be elevation> output=C:\delete\ai.txt
If I run this in WinGRASS text mode it places the data in file
c:\deleteai.txt (it ignores the '\'
If I run this in WinGRASS text mode but I place " " around the ouput it runs
OK and places the data in c:\delete\ai.txt
If I run this in WinGRASS wxPYTHON GUI it places the data in file
c:\deleteai.txt
If I run this in WinGRASS wxPYTHON GUI but I place " " around the the output
path it does not run and it get this error:
"C:Deleteai.txt": No such file or directory
So this is a problem of WxPython in Windows when it gets the file paths and
it sends to Scripts (Python or Bash Script)
Any suggestion on how to solve this?
Thanks
Katrin
2011/3/14 katrin eggert <katrineggert1980 at gmail.com>
> Hello Glynn
> First of all, thank you for replying to my emails...
>> Python accepts '\'. GRASS typically just passes filenames to the OS,
>> and Windows accepts '\'.
> Yes you are right. But for instance, if I try to run  r.out.xyz GRASS
> script (included in WiNGRASS standalone versions) like this: r.out.xyz
> input=1990 at climate output=C:\delete\ai.txt:
> - In bash Script it does not place it in c:\delete\ folder but it places in
> c:\ a file named deleteai.txt. This means that it's ignoring the '\'
> - Then, I tried with r.out.xyz Python script adn the same happened.
> This happens not only with r.out.xyz but also with other Bash and Python
> GRASS scripts.THe problem is that, when a user places a path to a file in
> Scripts GUI (in Windows OS), when it presses the run, "inside the script",
> the variable "loses" the '\'.
> THis is not specific this is for all GRASS Scripts (Bash and Python) that
> uses filepaths in Windows OS.
> Or am I analyzing this wrong?
> Katrin Eggert
URL: http://lists.osgeo.org/pipermail/grass-dev/attachments/20110314/9bf6ce23/attachment.html
