[GRASS-dev] text interface for GRASS70
Martin Landa landa.martin at gmail.com
Tue Mar 22 11:00:59 EDT 2011
2011/3/22 Martin Landa <landa.martin at gmail.com>:
> please try out r45726
> $ grass70 -c /home/martin/grassdata/test1
>> g.proj -p
> XY location (unprojected)
> $ grass70 -c ~/lakes.shp /home/martin/grassdata/test1
in r45727 you can also create new location based on EPSG
$ grass70 -c EPSG:4326 /home/martin/grassdata/test1
> g.proj -p
-PROJ_INFO-------------------------------------------------
proj       : ll
datum      : wgs84
ellps      : wgs84
no_defs    : defined
-PROJ_UNITS------------------------------------------------
unit       : degree
units      : degrees
meters     : 1.0
Martin
Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
