[GRASS-dev] Error with r.to.vect- Solved?
António Rocha antonio.rocha at deimos.com.pt
Wed Mar 30 09:35:42 EDT 2011
Hi Markus
Thanks for the feedback but I am running in WinGRASS. Just two questions:
- Is it possible to have Long File Support in wiNGRASS 6.4?
- Since I'm running this in a Script, how can I define  " export
GRASS_VECTOR_LOW_MEM=1  " in a Python Script?
Thanks
Antonio
Markus Metz wrote:
> 2011/3/29 António Rocha <antonio.rocha at deimos.com.pt>:
>> Hello Markus
>> Unfortunely, I get this error when I run other datasets. In this case, a
>> landCover with all CELLS and spatial resolution of 30. The problem is that
>> North carolina sample is too small.
>> r.to.vect -v input=FULL at PERMANENT output=FULL feature=area
>> I get this:
>> Default driver / database set to:
>> driver: dbf
>> database: $GISDBASE/$LOCATION_NAME/$MAPSET/dbf/
>> Extracting areas...
>> Building topology for vector map <PT_National_2000_FULL>...
>> R4243000ERROR: G_realloc: unable to allocate 16976004 bytes at
>> struct_alloc.c:133
>> It has created a vector but I cannot display and I cannot use v.info (it
>> says that I need to build topology).
>> And If I try to build topology I get and error and before this warning:
>> Coor files of vector map <PT_National_2000_FULL at PERMANENT> is larger than it
>> should be (241464079 bytes excess)
>> So my questions are:
>> 1- Is any fix for this?
>> 2- If not, is there any defined limit for a raster in order to be converted
>> to vector?
> Since this is an out-of-memory error, you could try grass 7 and in your terminal
> export GRASS_VECTOR_LOW_MEM=1
> before running r.to.vect. This will reduce memory requirements while
> building topology. Large File Support is probably not needed here, but
> nowadays a good thing to have, just in case.
> Markus M
>> Markus Neteler wrote:
>>> 2011/3/23 António Rocha <antonio.rocha at deimos.com.pt>:
>>>> A couple of months ago I sent a few messages regarding a memorry error
>>>> with
>>>> r.to.vect (it was allocating to many information and data). My question
>>>> is,
>>>> sicne r.to.vect was not updated, is there any raster or vector lib update
>>>> that had any impact on this?
>>> Did you post a test case? Best done with the North Carolina sample
>>> data set. Otherwise it is hard to replicate...
>>> Markus
__________ Information from ESET NOD32 Antivirus, version of virus signature database 6000 (20110330) __________
The message was checked by ESET NOD32 Antivirus.
http://www.eset.com
