[GRASS-dev] Error with r.to.vect- Solved?
Markus Metz markus.metz.giswork at googlemail.com
Wed Mar 30 06:39:45 EDT 2011
2011/3/29 António Rocha <antonio.rocha at deimos.com.pt>:
> Hello Markus
> Unfortunely, I get this error when I run other datasets. In this case, a
> landCover with all CELLS and spatial resolution of 30. The problem is that
> North carolina sample is too small.
> r.to.vect -v input=FULL at PERMANENT output=FULL feature=area
> I get this:
> Default driver / database set to:
> driver: dbf
> database: $GISDBASE/$LOCATION_NAME/$MAPSET/dbf/
> Extracting areas...
> Building topology for vector map <PT_National_2000_FULL>...
> R4243000ERROR: G_realloc: unable to allocate 16976004 bytes at
> struct_alloc.c:133
> It has created a vector but I cannot display and I cannot use v.info (it
> says that I need to build topology).
> And If I try to build topology I get and error and before this warning:
> Coor files of vector map <PT_National_2000_FULL at PERMANENT> is larger than it
> should be (241464079 bytes excess)
> So my questions are:
> 1- Is any fix for this?
> 2- If not, is there any defined limit for a raster in order to be converted
> to vector?
Since this is an out-of-memory error, you could try grass 7 and in your terminal
export GRASS_VECTOR_LOW_MEM=1
before running r.to.vect. This will reduce memory requirements while
building topology. Large File Support is probably not needed here, but
nowadays a good thing to have, just in case.
Markus M
> Markus Neteler wrote:
>> 2011/3/23 António Rocha <antonio.rocha at deimos.com.pt>:
>>> A couple of months ago I sent a few messages regarding a memorry error
>>> with
>>> r.to.vect (it was allocating to many information and data). My question
>>> is,
>>> sicne r.to.vect was not updated, is there any raster or vector lib update
>>> that had any impact on this?
>> Did you post a test case? Best done with the North Carolina sample
>> data set. Otherwise it is hard to replicate...
>> Markus
