[GRASS-dev] Re: [GRASS GIS] #854: g.extension does not work on a
Mac (probably not on Windows either
trac at osgeo.org
Wed May 11 23:34:33 EDT 2011
#854: g.extension does not work on a Mac (probably not on Windows either
Reporter: cmbarton | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 6.4.2
Component: Installation | Version: 6.4.1 RCs
Keywords: g.extension, addons | Platform: All
Cpu: All |
Comment(by kyngchaos):
In adding the install for g.html2man (r46240 in rel64, r46241 in dev6), I
found an update (r45933) by martinl that did that, though it was broken
(didn't make sure g.html2man subfolder existed). But also he had an old
copy of the Makefile and I had to fix a reversion.
And instead of my changes to g.extension to change ARCH_* vars, martin
hacked platform.make, grass.make and man.make on install to change the
make vars.
Though it probably needs a few more vars updated to match what I did,
which is the better method? Seems to me to change 1 file, g.extension, is
better than to change 3. But maybe there are other uses for the makefiles
outside g.extension?
I guess both methods won't hurt...
Ticket URL: <http://trac.osgeo.org/grass/ticket/854#comment:9>
