[GRASS-dev] nviz_cmd in winGRASS
Helena Mitasova hmitaso at ncsu.edu
Thu Sep 29 23:59:00 EDT 2011
I will have to update some assignments if the name is changed, but it should not be too much.
It will be better to rename it now rather than later, so +1 for the new name
Helena
On Sep 29, 2011, at 11:32 PM, Hamish wrote:
> Martin wrote:
>> I would prefer to rename nviz_cmd to m.nviz.image also in
>> GRASS6. It's quite new module which is not used by normal users,
> who among us are normal users? :-)
> (but seriously, I think one of the great draws of grass is that
> it lets you do (or adapt the code to) odd-ball tasks which less
> modifiable software lock you out of. it's a big reason why I first
> started using it)
>> so I think that we could rename it too (before 6.4.2).
> sounds good to me. see grass64/scripts/r.cats for a model of
> leaving behind a link to the old name, if that's necessary.
> (is the 6.x version scriptable?)
> Hamish
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
