[GRASS-dev] Re: GRASS 6.4.2RC1 planning
Helmut Kudrnovsky hellik at web.de
Fri Sep 30 14:50:11 EDT 2011
Hamish,
>GRASS_HOME and RUN_GISBASE
>(to respond to Glynn's suggestion to split the files: not a
>general solution, but: can these values be overridden on the
>command line at runtime using g.extension's prefix= answer?
>at least that would help for g.extension)
>here's the sed I used to replace it with "/usr/lib/grass64"
>on debian:
>        # adjust from build-server build dir to end-user's install dir
>        sed -i -e "s+^\(GRASS_HOME[ ]*=\) .*+\1 /usr/lib/$(BASE_NAME)+" \
>                -e "s+^\(RUN_GISBASE[ ]*=\) .*+\1 /usr/lib/$(BASE_NAME)+" \
>                debian/tmp/usr/lib/$(BASE_NAME)/include/Make/Platform.make
[sorry no sed-expert here on my side]
checked with nightly build WinGRASS-6.4.SVN-r48555-1-Setup.exe, installation
folder is C:\Program Files\GRASS 6.4.SVN\ (german winvista32-box)
following left overs from the osgeo4w-build-environment of the
wingrass-installer
C:\Program Files\GRASS 6.4.SVN\include\Make\Platform.make
	prefix              = /c/OSGeo4W/apps/grass
	exec_prefix         = ${prefix}
	ARCH                = i686-pc-mingw32
	UNIX_BIN            = /c/OSGeo4W/bin
	INST_DIR            = ${prefix}/grass-6.4.2svn
	# GRASS dirs
	GRASS_HOME          = /c/OSGeo4W/apps/grass/grass-6.4.2svn
	RUN_GISBASE         = /c/OSGeo4W/apps/grass/grass-6.4.2svn
	RUN_GISRC           =
${ARCH_DISTDIR}/demolocation/.grassrc${GRASS_VERSION_MAJOR}${GRASS_VERSION_MINOR}
	CPPFLAGS            =   -I/c/OSGeo4W/include
	CFLAGS1             = -g -O2
	CXXFLAGS1           = -g -O2
	INCLUDE_DIRS        =  -I/c/OSGeo4W/include
	COMPILE_FLAGS       = $(CPPFLAGS) $(CFLAGS1) $(INCLUDE_DIRS)
	COMPILE_FLAGS_CXX   = $(CPPFLAGS) $(CXXFLAGS1) $(INCLUDE_DIRS)
	LINK_FLAGS          =   -Wl,--export-dynamic,--enable-runtime-pseudo-reloc
-L/c/OSGeo4W/lib -L/osgeo4w/usr/src/grass64_release/mswindows/osgeo4w/lib
	#GDAL/OGR
	GDALLIBS            = /c/OSGeo4W/lib/gdal_i.lib
	GDALCFLAGS          = -I/c/OSGeo4W/include
	USE_GDAL            = 1
	USE_OGR             = 1
	#GEOS
	GEOSLIBS            = /c/OSGeo4W/lib/geos_c_i.lib -lgeos_c_i
	GEOSCFLAGS          = -I/c/OSGeo4W/include
	USE_GEOS            = 1
	#FreeType:
	FTINC               =  -I/c/OSGeo4W/include/freetype2
	FTLIB               =  -lfreetype
	#PROJ.4:
	PROJINC             =  $(GDALCFLAGS)
	PROJLIB             =  -lproj
	NAD2BIN             = /c/OSGeo4W/bin/nad2bin
	PROJSHARE           = /c/OSGeo4W/share/proj
C:\Program Files\GRASS 6.4.SVN\include\Make\Grass.make
	# GRASS global directories and constants
	# platform specific dirs
	ARCH_DISTDIR	= /c/OSGeo4W/apps/grass/grass-6.4.2svn
	ARCH_BINDIR     = /c/OSGeo4W/bin
	ERRORLOG        = $(GRASS_HOME)/error.log
maybe you could indicate which of mentioned osgeo4w-leftovers should be
changed.
that would be helpful changing the nsis-installer
best regards
Helmut
View this message in context: http://osgeo-org.1803224.n2.nabble.com/GRASS-6-4-2RC1-planning-tp6835951p6848892.html
Sent from the Grass - Dev mailing list archive at Nabble.com.
