[GRASS-dev] Speed map display in wxGUI on bigger monitors
Markus Neteler
neteler at osgeo.org
Fri Aug 3 07:19:59 PDT 2012
when working with the wxGUI on bigger monitors, it is rather slow
when it comes to map display.
Looking into the /tmp/ directory, I find fairly huge files which are
generated and then combined for display.
It is getting even worse when using GRASS over network.
Question: why the uncompressed PNM/PPM format used by g.pnmcomp?
Markus
