[GRASS-dev] Speed map display in wxGUI on bigger monitors
Markus Neteler neteler at osgeo.org
Mon Aug 13 07:57:39 PDT 2012
On Fri, Aug 3, 2012 at 4:19 PM, Markus Neteler <neteler at osgeo.org> wrote:
> Hi,
> when working with the wxGUI on bigger monitors, it is rather slow
> when it comes to map display.
> Looking into the /tmp/ directory, I find fairly huge files which are
> generated and then combined for display.
> It is getting even worse when using GRASS over network.
> Question: why the uncompressed PNM/PPM format used by g.pnmcomp?
... I am still interested to understand this...
thanks
Markus
