[GRASS-dev] Grass7 GUI compilation failed
Rashad M mohammedrashadkm at gmail.com
Sat Dec 29 10:25:17 PST 2012
here is output from v.digit
make
ml
make[6]: Entering directory `/code/grass/grass70/gui/wxpython/vdigit'
GISRC=/code/grass/grass70/dist.x86_64-unknown-linux-gnu/demolocation/.grassrc70
GISBASE=/code/grass/grass70/dist.x86_64-unknown-linux-gnu
PATH="/code/grass/grass70/dist.x86_64-unknown-linux-gnu/bin:/code/grass/grass70/dist.x86_64-unknown-linux-gnu/bin:$PATH"
PYTHONPATH="/code/grass/grass70/dist.x86_64-unknown-linux-gnu/etc/python:/code/grass/grass70/dist.x86_64-unknown-linux-gnu/etc/python:$PYTHONPATH"
LD_LIBRARY_PATH="/code/grass/grass70/dist.x86_64-unknown-linux-gnu/bin:/code/grass/grass70/dist.x86_64-unknown-linux-gnu/lib:/code/grass/grass70/dist.x86_64-unknown-linux-gnu/lib:"
LC_ALL=C
/code/grass/grass70/dist.x86_64-unknown-linux-gnu/scripts/g.gui.vdigit
--html-description < /dev/null | grep -v '</body>\|</html>' >
g.gui.vdigit.tmp.html
  File
"/code/grass/grass70/dist.x86_64-unknown-linux-gnu/scripts/g.gui.vdigit",
line 39, in <module>
    import wx
ImportError: No module named wx
make[6]: *** [g.gui.vdigit.tmp.html] Error 1
rm g.gui.vdigit.tmp.html
make[6]: Leaving directory `/code/grass/grass70/gui/wxpython/vdigit'
make[5]: *** [guiscript] Error 2
On Sat, Dec 29, 2012 at 9:57 PM, Rashad M <mohammedrashadkm at gmail.com>wrote:
> grass7.0 fails compilation at first and continues only after setting
> PYTHONPATH.
> This becomes a routine for recompilation. Is there any work around to
> automatically pickup wxPython?
> Here is my error log:
> Started compilation: Sat Dec 29 21:46:17 IST 2012
> Errors in:
> /code/grass/grass70/gui/wxpython/animation
> /code/grass/grass70/gui/wxpython/mapswipe
> /code/grass/grass70/gui/wxpython/gmodeler
> /code/grass/grass70/gui/wxpython/rlisetup
> /code/grass/grass70/gui/wxpython/psmap
> /code/grass/grass70/gui/wxpython/dbmgr
> In case of errors please change into the directory with error and run
> 'make'.
> If you get multiple errors, you need to deal with them in the order they
> appear in the error log. If you get an error building a library, you will
> also get errors from anything which uses the library.
> Finished compilation: Sat Dec 29 21:53:10 IST 2012
> wxpython is installed from ubuntu repos. so its in the default path
> Regards,
>    Rashad
Regards,
   Rashad
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20121229/5dee8ec3/attachment.html>
