[GRASS-dev] Grass7 GUI compilation failed
Michael Barton Michael.Barton at asu.edu
Sat Dec 29 12:57:13 PST 2012
This has been broken since the introduction of the animation module and apparently now is affecting other modules that used to compile fine. So GRASS 7 is increasingly broken for the Mac. Volume displays have been broken for many months now. If someone could tell me what has changed with the introduction of these new modules and related changes to the other ones, I might be able to find out what is breaking on the Mac. I'm guessing that it is a new class that calls some wxPython windowing routine that has a problem, but I don't know what it is.
Michael
____________________
C. Michael Barton
Director, Center for Social Dynamics & Complexity
Professor of Anthropology, School of Human Evolution & Social Change
Arizona State University
voice:  480-965-6262 (SHESC), 480-727-9746 (CSDC)
fax:          480-965-7671 (SHESC),  480-727-0709 (CSDC)
www: http://www.public.asu.edu/~cmbarton, http://csdc.asu.edu
On Dec 29, 2012, at 1:00 PM, <grass-dev-request at lists.osgeo.org<mailto:grass-dev-request at lists.osgeo.org>>
 wrote:
From: Rashad M <mohammedrashadkm at gmail.com<mailto:mohammedrashadkm at gmail.com>>
Subject: Re: [GRASS-dev] Grass7 GUI compilation failed
Date: December 29, 2012 11:25:17 AM MST
To: <grass-dev at lists.osgeo.org<mailto:grass-dev at lists.osgeo.org>>
here is output from v.digit
make
ml
make[6]: Entering directory `/code/grass/grass70/gui/wxpython/vdigit'
GISRC=/code/grass/grass70/dist.x86_64-unknown-linux-gnu/demolocation/.grassrc70 GISBASE=/code/grass/grass70/dist.x86_64-unknown-linux-gnu PATH="/code/grass/grass70/dist.x86_64-unknown-linux-gnu/bin:/code/grass/grass70/dist.x86_64-unknown-linux-gnu/bin:$PATH" PYTHONPATH="/code/grass/grass70/dist.x86_64-unknown-linux-gnu/etc/python:/code/grass/grass70/dist.x86_64-unknown-linux-gnu/etc/python:$PYTHONPATH" LD_LIBRARY_PATH="/code/grass/grass70/dist.x86_64-unknown-linux-gnu/bin:/code/grass/grass70/dist.x86_64-unknown-linux-gnu/lib:/code/grass/grass70/dist.x86_64-unknown-linux-gnu/lib:" LC_ALL=C /code/grass/grass70/dist.x86_64-unknown-linux-gnu/scripts/g.gui.vdigit --html-description < /dev/null | grep -v '</body>\|</html>' > g.gui.vdigit.tmp.html
  File "/code/grass/grass70/dist.x86_64-unknown-linux-gnu/scripts/g.gui.vdigit", line 39, in <module>
    import wx
ImportError: No module named wx
make[6]: *** [g.gui.vdigit.tmp.html] Error 1
rm g.gui.vdigit.tmp.html
make[6]: Leaving directory `/code/grass/grass70/gui/wxpython/vdigit'
make[5]: *** [guiscript] Error 2
On Sat, Dec 29, 2012 at 9:57 PM, Rashad M <mohammedrashadkm at gmail.com<mailto:mohammedrashadkm at gmail.com>> wrote:
grass7.0 fails compilation at first and continues only after setting PYTHONPATH.
This becomes a routine for recompilation. Is there any work around to automatically pickup wxPython?
Here is my error log:
Started compilation: Sat Dec 29 21:46:17 IST 2012
Errors in:
/code/grass/grass70/gui/wxpython/animation
/code/grass/grass70/gui/wxpython/mapswipe
/code/grass/grass70/gui/wxpython/gmodeler
/code/grass/grass70/gui/wxpython/rlisetup
/code/grass/grass70/gui/wxpython/psmap
/code/grass/grass70/gui/wxpython/dbmgr
In case of errors please change into the directory with error and run 'make'.
If you get multiple errors, you need to deal with them in the order they
appear in the error log. If you get an error building a library, you will
also get errors from anything which uses the library.
Finished compilation: Sat Dec 29 21:53:10 IST 2012
wxpython is installed from ubuntu repos. so its in the default path
Regards,
   Rashad
Regards,
   Rashad
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20121229/59906bab/attachment.html>
