[GRASS-dev] MASK indicated on map display even after it was removed in GRASS 6.4.3 release
Anna Kratochvílová
kratochanna at gmail.com
Thu Nov 15 09:13:08 PST 2012
On Thu, Nov 15, 2012 at 4:10 PM, Helena Mitasova <hmitaso at ncsu.edu> wrote:
> On Nov 15, 2012, at 8:27 AM, Markus Metz wrote:
>> On Thu, Nov 15, 2012 at 10:45 AM, Martin Landa <landa.martin at gmail.com> wrote:
>>> Hi Helena,
>>> 2012/11/15 Helena Mitasova <hmitaso at ncsu.edu>:
>>>> This is not a serious problem but I just noticed that the grass6.4.3 compiled on oct 18 on mac
>>>> the red word MASK remains on the Map display even after the MASK is removed.
>>>> I don't seem to find a way how to get rid of it.
>>> tested with fresh 6.4.3svn. After removing the mask (`r.mask -r`) the
>>> indicator is also removed from the Map Display.
>>> Unfortunately I cannot reproduce this problem. Martin
>> You can reproduce it if you create a MASK in one mapset, then change
>> to another mapset without a MASK, but with the first mapset in the
>> search path. If a MASK is found in any mapset in the search path, the
>> red word MASK will appear in the Map display. But only MASKs in the
>> current mapset are respected by raster operations, thus that red word
>> MASK should not be there in this case.
Should be fixed in all branches now (53839, 40, 41).
Anna
> yes, that is exactly my case, I have a MASK in another mapset,
> Helena
>> Markus M
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
