[GRASS-dev] [GRASS GIS] #1775: v.surf.rst does not respect mask
GRASS GIS trac at osgeo.org
Sun Nov 18 23:42:45 PST 2012
 Reporter:  cmbarton     |       Owner:  grass-dev@…
     Type:  defect       |      Status:  new
 Priority:  normal       |   Milestone:  7.0.0
Component:  Vector       |     Version:  svn-trunk
 Keywords:  v.surf.rst   |    Platform:  Unspecified
      Cpu:  Unspecified  |
Comment(by annakrat):
 When you have a look at
 [http://trac.osgeo.org/grass/browser/grass/trunk/lib/raster/set_window.c#L157
 the code calling fatal error], there is some additional functionality
 after G_fatal_error which is nonsense. Maybe there should be a warning
 instead or the following line should be removed to avoid confusion.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1775#comment:2>
