[GRASS-dev] "Parameter <layer>, require: string" in v.db.dropcolumn
Nikos Alexandris nik at nikosalexandris.net
Mon Nov 19 02:42:47 PST 2012
Hi all!
Using "v.db.dropcolumn" within from latest "grass_trunk",
I wonder why the "layer" parameter in "v.db.dropcolumn" is required to be a
string as stated in an error message while trying to run a py-grass script:
File "/geo/osgeo/src/grass_trunk/dist.x86_64-unknown-linux-
gnu/etc/python/grass/pygrass/modules/__init__.py", line 466, in __call__
    self.inputs[key].value = val
gnu/etc/python/grass/pygrass/modules/__init__.py", line 182, in _set_value
    raise TypeError(str_err % (self.name, self.typedesc, type(value)))
TypeError: The Parameter <layer>, require: string, get: <type 'int'> instead
Shouldn't the "layer" parameter be simply an integer?
Thanks, Nikos
