[GRASS-dev] [GRASS GIS] #1629: v.in.db - odbc-driver - access-database: not working
GRASS GIS trac at osgeo.org
Fri Oct 5 02:03:38 PDT 2012
  Reporter:  hellik           |       Owner:  grass-dev@…
      Type:  defect           |      Status:  closed
  Priority:  critical         |   Milestone:  6.4.3
 Component:  Database         |     Version:  svn-releasebranch64
Resolution:  invalid          |    Keywords:  wingrass, db, odbc
  Platform:  MSWindows Vista  |         Cpu:  x86-32
Changes (by mlennert):
  * status:  new => closed
  * resolution:  => invalid
Comment:
 Replying to [comment:5 mlennert]:
 > I believe that unless there is more info about the ODBC access failing
 when used correctly, this bug should be closed as invalid.
 As nothing has been posted since, I'm closing this bug as invalid.
 Moritz
Ticket URL: <http://trac.osgeo.org/grass/ticket/1629#comment:6>
