[GRASS-dev] [GRASS GIS] #1270: wingrass: Error in Attribute Table Manager
GRASS GIS trac at osgeo.org
Fri Oct 5 02:10:22 PDT 2012
 Reporter:  antonioall                         |       Owner:  grass-dev@…
     Type:  defect                             |      Status:  new
 Priority:  critical                           |   Milestone:  6.4.2
Component:  wxGUI                              |     Version:  svn-develbranch6
 Keywords:  wingrass, attribute table manager  |    Platform:  MSWindows Vista
      Cpu:  x86-32                             |
Comment(by mlennert):
 Replying to [comment:3 hamish]:
 > Hi,
 > I can reproduce this in 6.5svn nightly build on Windows XP.
 > steps as described in the orig report, add a new vector column, edit a
 row, hit submit.
 > error is now:
 > Error:
 > c:\docume~1\hamish\locals~1\temp\tmpuelgf4: Permission denied
 Working with a student yesterday, I saw a similar error trying to add a
 new column.
 We were trying to digitize, so I thought it was because the table was open
 for the digitization, but even when we ended that, no way to add a new
 column.
 Even calling v.db.addcol ended in an error. This all happened in a hurry,
 so I don't have the exact errors and cannot reproduce right now. Anyone
 can confirm that this also happens when you try to add a column ? This was
 with a grass6.4.3svn install (don't have the revision number).
 Moritz
Ticket URL: <http://trac.osgeo.org/grass/ticket/1270#comment:9>
