[GRASS-dev] [GRASS GIS] #2052: r.in.gdal should not by default call first three bands red, green, blue
GRASS GIS trac at osgeo.org
Thu Aug 1 04:13:40 PDT 2013
 Reporter:  mlennert        |       Owner:  grass-dev@…
     Type:  enhancement     |      Status:  new
 Priority:  normal          |   Milestone:  7.0.0
Component:  Raster          |     Version:  svn-trunk
 Keywords:  r.in.gdal, rgb  |    Platform:  Unspecified
      Cpu:  Unspecified     |
Comment(by mlennert):
 Replying to [comment:5 mmetz]:
 > Replying to [comment:4 mlennert]:
 > > Replying to [comment:2 hamish]:
 > > > I'm not 100% sure, but ISTR that it was libgdal doing that,
 r.in.gdal was just passing the band name along untouched. --> gdal band
 name detection bug?
 > > Yes and no: GDAL does return a !ColorInterp info which is "wrong", but
 this is apparently due to the original data:
 [https://trac.osgeo.org/gdal/ticket/5177]
 > > The problem in r.in.gdal is here:
 [https://trac.osgeo.org/grass/browser/grass/trunk/raster/r.in.gdal/main.c#L525].
 > That means the -k flag should be removed and the band number always used
 as suffix, or optionally the meaning of the -k flag should be reverted
 such that color names are appended only on request?
 Duh. I have to admit that I completely overlooked this flag. So the
 question is: what is less confusion for newcomers: have rgb extensions
 sometimes not be correct, or always only have numbers ?
 Moritz
Ticket URL: <https://trac.osgeo.org/grass/ticket/2052#comment:6>
