[GRASS-dev] [GRASS GIS] #2052: r.in.gdal should not by default call first three bands red, green, blue
GRASS GIS trac at osgeo.org
Thu Aug 1 04:58:53 PDT 2013
 Reporter:  mlennert        |       Owner:  grass-dev@…
     Type:  enhancement     |      Status:  new
 Priority:  normal          |   Milestone:  7.0.0
Component:  Raster          |     Version:  svn-trunk
 Keywords:  r.in.gdal, rgb  |    Platform:  Unspecified
      Cpu:  Unspecified     |
Comment(by hamish):
 Replying to [comment:6 mlennert]:
 > So the question is: what is less confusion for newcomers: have rgb
 > extensions sometimes not be correct, or always only have numbers ?
 I'd go with option (c): complain to the data providers until they correct
 their files. Better result for everyone in the long run.
 rouault:
 > > From the above output, the file must have TIFFTAG_PHOTOMETRIC
 (wrongly) set to
 > > PHOTOMETRIC_RGB. So the problem is more on the producer of the file.
 Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/2052#comment:7>
