[GRASS-dev] standalone installer cleanup
Helmut Kudrnovsky hellik at web.de
Fri Aug 2 03:17:42 PDT 2013
hi,
Martin Landa wrote
> 2013/8/2 Martin Landa <
> landa.martin@
>> 2013/8/2 Hamish <
> hamish_b@
>>> re. r57342, the PROJ_LIB variable is needed by e.g. cs2cs used by some
>>> scripts,
>> are you sure about that?, proj lib in the path (`extralib`) or it
>> refers to share stuff?
> quickly checking proj manual. IAIW, PROJ_LIB should point to the
> `share` directory. If so I will restore this environmental variable.
> Martin
> grass-dev mailing list
> grass-dev at .osgeo
> http://lists.osgeo.org/mailman/listinfo/grass-dev
thanks for restoring.
have a quick look in
wingrass, gdal, proj4
http://trac.osgeo.org/grass/ticket/1201
and
http://lists.osgeo.org/pipermail/osgeo4w-dev/2010-October/001102.html
>They should all be include with wingrass.
>GDAL_DATA=C:\OSGeo4W\share\gdal
>PROJ_LIB=C:\OSGeo4W\share\proj
>GEOTIFF_CSV=C:\OSGeo4W\share\epsg_csv
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/standalone-installer-cleanup-tp5070418p5070434.html
Sent from the Grass - Dev mailing list archive at Nabble.com.
