[GRASS-dev] GDAL,GRASS 7 and PostGIS on Ubunutu 12.04
Markus Neteler neteler at osgeo.org
Thu Dec 12 03:04:55 PST 2013
(cc F Warmerdam)
On Thu, Dec 12, 2013 at 10:33 AM, Blumentrath, Stefan
<Stefan.Blumentrath at nina.no> wrote:
> Hi Markus
> Thanks for your feedback.
> I had read ticket #2953 and found it a bit confusing in that sense that Martin modified GDAL (and not the plugin). The plugin (on http://download.osgeo.org/gdal/) was last modified 05-Aug-2007. To me it seems that GDAL is now (with Martins fixes in place) using a mixture of GRASS 6 and 7 libs. GDAL itself does not complain (if both GRASS versions can be found) but raster2pgsql does (and maybe OGR would as well)...
..to my knowledge the GDAL plugin is nothing else than the source code
extraction from main GDAL into a separate package.
> Looks like both GDAL and the GRASS-GDAL plugin need some update...
I think that the GDAL-GRASS plugin code should be re-extracted as a package.
> Shall I add an error-report to ticket #2953?
yes, please.
best
Markus
> Cheers
> Stefan
> -----Original Message-----
> From: neteler.osgeo at gmail.com [mailto:neteler.osgeo at gmail.com] On Behalf Of Markus Neteler
> Sent: 11. desember 2013 15:18
> To: Blumentrath, Stefan
> Cc: grass-dev at lists.osgeo.org
> Subject: Re: [GRASS-dev] GDAL,GRASS 7 and PostGIS on Ubunutu 12.04
> On Wed, Dec 11, 2013 at 12:26 PM, Blumentrath, Stefan <Stefan.Blumentrath at nina.no> wrote:
>> Dear all,
>> Do not know if this post belongs here or to PostGIS:
>> I compiled GDAL (rev 26701) with support for GRASS 7 (not the plugin but recompiled GDAL with GRASS support after building GRASS 7 from source (rev 58438)).
> I don't think that GDAL is already compliant with GRASS 7:
> See http://trac.osgeo.org/gdal/ticket/2953
>> /usr/local/grass-7.0.svn/lib
>> /usr/local/grass-6.4.4svn/lib
>> In /etc/ld.so.conf (in that order).
> I guess the order should be reverse.
>> gdal_translate gives a warning message:
>> Warning 1: GRASS warning: GISBASE enviroment variable was not set, using:
>> However, it takes GRASS raster gladly, so that works.
> ... for me surprising :-)
>> Then I build PostGIS 2.1.2 against the compiled GDAL version with GRASS support.
>> Unfortunately raster2pgsql gives error messages when I try to feed GRASS raster:
>> "Segmentation fault (core dumped)"
>> After I removed the link to GRASS 6.4.4svn/lib in /etc/ld.so.conf the errormessage changes to:
>> ERROR 1: libgrass_I.so: cannot open shared object file: No such file
>> or directory
>> *** glibc detected *** raster2pgsql: corrupted double-linked list:
>> 0x00000000012e59f0 ***
>> Any Ideas?
> IMHO the GDAL ticket should be fixed.
> Best
> Markus
