[GRASS-dev] GRASS7.0 on Mavericks
Yann Chemin ychemin at gmail.com
Sun Dec 15 07:18:13 PST 2013
Thank you Anna,
it works as main owner of the machine, not as an additional user...
Will try,
Yann
On 15 December 2013 20:25, Anna Petrášová <kratochanna at gmail.com> wrote:
> Hi Yann,
> I don't think this problem relates to toolboxes. The error message is
> completely different. I would first suggest to install new Python version
> 2.7.6 [1] because there have been some problems and Python had to release
> new version. If this does not help, unfortunately I have no other idea.
> Anna
> [1] http://www.python.org/getit/
> On Sun, Dec 15, 2013 at 2:43 AM, Yann Chemin <ychemin at gmail.com> wrote:
>> Oh yes I remember some times back reading about it, apologies.
>> On 15 December 2013 02:19, Michael Barton <c.michael.barton at gmail.com>wrote:
>>> This is the bug I've been reporting for months now. It was introduced
>>> with the new tool box feature. There is a work around I can send you when
>>> I'm back at a computer. But it really needs to be found and fixed. Anna and
>>> I have tried to track it down without success yet.
>>> Michael Barton
>>> Sent from my iPhone...
>>> (so please excuse any typos)
>>> On Dec 14, 2013, at 5:51 AM, Yann Chemin <ychemin at gmail.com> wrote:
>>> Hi,
>>> I created a new user (also administrator) on a MacBook and started to
>>> follow Michael's steps to install version 7 Maverick
>>> I get a strange error on install, the directory GRASS (inside is the
>>> application grass-7.0) is there but I do not have permission to open the
>>> directory in Finder (though I did install it). Going to the "main" user of
>>> the machine I could change the permissions, and also checked that GRASS7.0
>>> runs well, all good there, no worries.
>>> Going back to my user, I can go in the directory, and launch the
>>> application, ok. Then things go weird. It was working well in the "main"
>>> user but bugs in that new user... Both have admin level.
>>> Python 2.7.5 found.
>>> WELCOME TO GRASS 7.0.svn
>>>    1) Have at your side all available GRASS GIS tutorials
>>>    2) When working on your location, the following materials
>>>       are extremely useful:
>>>       - A topographic map of your area
>>>       - Current catalog of available computer maps
>>>    3) heck the GRASS GIS web pages for supporting mailing lists and more:
>>>       http://grass.osgeo.org
>>> Hit RETURN to continue
>>> Starting GRASS GIS...
>>> Traceback (most recent call last):
>>>   File
>>> "/Applications/GRASS/GRASS-7.0.app/Contents/MacOS/etc/gui/wxpython/gis_set.py",
>>> line 37, in <module>
>>>     from core.utils import _
>>>   File
>>> "/Applications/GRASS/GRASS-7.0.app/Contents/MacOS/etc/gui/wxpython/core/utils.py",
>>> line 36, in <module>
>>>     from core.gcmd  import RunCommand
>>>   File
>>> "/Applications/GRASS/GRASS-7.0.app/Contents/MacOS/etc/gui/wxpython/core/gcmd.py",
>>> line 744, in <module>
>>>     _enc = GetDefaultEncoding() # define as global variable
>>>   File
>>> line 737, in GetDefaultEncoding
>>>     enc = locale.getdefaultlocale()[1]
>>>   File
>>> "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/locale.py",
>>> line 511, in getdefaultlocale
>>>     return _parse_localename(localename)
>>>   File
>>> line 443, in _parse_localename
>>>     raise ValueError, 'unknown locale: %s' % localename
>>> ValueError: unknown locale: UTF-8
>>> Error in GUI startup. If necessary, please report this error to the
>>> GRASS developers.
>>> Switching to text mode now.
>> grass-dev mailing list
>> grass-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20131215/59fe8277/attachment.html>
