[GRASS-dev] [GRASS GIS] #2004: wxgui: ctrl-t to tile layer manager and map window full screen
GRASS GIS trac at osgeo.org
Fri Jun 14 02:09:43 PDT 2013
 Reporter:  hamish         |       Owner:  grass-dev@…
     Type:  enhancement    |      Status:  new
 Priority:  normal         |   Milestone:  6.4.4
Component:  wxGUI          |     Version:  svn-trunk
 Keywords:  window layout  |    Platform:  All
      Cpu:  All            |
 it would be very handy to make ctrl-t tile the layer manager and map
 window side by side, full screen.
 the idea is to read the desktop size in pixels, split it up ~1.7:1 ratio
 with the wider (squarer) map display on the right, but if that makes the
 layer manager wider than 700px max it out at that and make the map window
 wider to fill in the gap between them.
 On my system with default (AFAIK) fonts 700px wide layer manager window
 gets the output window tab and the '>>> ' python prompt tab to allow 80
 chars of text to fit without wrapping. (e.g. for r.info report output)
 maybe if multiple map windows are open tile them top-to-bottom on the
 right side.
 I'm not sure if it can control the launching Terminal prompt (xterm)
 window, maybe the best we could do there is split the left-side upper
 2/3rds for the layer manager and leave the bottom 1/3rd empty for the user
 to move the window there themselves? (or just ignore it and make the layer
 manager be full-height on the left side)
 thoughts?
 Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/2004>
