[GRASS-dev] [GRASS GIS] #2004: wxgui: ctrl-t to tile layer manager and map window full screen
GRASS GIS trac at osgeo.org
Sun Jun 16 01:14:30 PDT 2013
 Reporter:  hamish         |       Owner:  grass-dev@…
     Type:  enhancement    |      Status:  new
 Priority:  normal         |   Milestone:  6.4.4
Component:  wxGUI          |     Version:  svn-trunk
 Keywords:  window layout  |    Platform:  All
      Cpu:  All            |
Comment(by hamish):
 attached is come code to tile the map windows, but I'm not sure where it
 should go or how to bind that to ctrl-t in gui_core/forms.py. Ideally the
 keybinding should work from the layer manager or any map window. (I note
 that ctrl-q and ctrl-w only work from the layer manager window currently,
 it would be good to extend that too)
 Also the elif cases could probably be better collapsed into something a
 bit more elegant, it's just proof of concept. No idea how it behaves on a
 dual monitor setup.
 Finally, I notice that you get a beyond index traceback error after you
 open a fifth+ map display window.
 Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/2004#comment:1>
