[GRASS-dev] problem with house.c and GCC-4.7
Rashad M mohammedrashadkm at gmail.com
Fri Jun 21 09:57:44 PDT 2013
Did any one have solution?. I also got same error on lauchpad build for
raring 32bit. But both i386 and amd64 build for precise came clean.
You can see full log here [1]
[1]
https://launchpadlibrarian.net/143047971/buildlog_ubuntu-raring-i386.grass70_7.0.0%2B0ubuntu2%2B28630~raring1_FAILEDTOBUILD.txt.gz
I am waiting for amd64 build and let me see if the problem comes with only
32 bit as Vaclav pointed out
PS: If you have problem viewing this link please let me know
On Thu, Jun 20, 2013 at 4:45 PM, Yann Chemin <ychemin at gmail.com> wrote:
> I have not had that problem after upgrading the machine...
> On 20 June 2013 15:38, Vaclav Petras <wenzeslaus at gmail.com> wrote:
> > On 20 June 2013 11:44, Vaclav Petras <wenzeslaus at gmail.com> wrote:
> >> Hi Yann,
> >> On 27 May 2013 09:51, Yann Chemin <ychemin at gmail.com> wrote:
> >>> Hi
> >>> Using Ubuntu 13.04
> >>> gcc  -g -O2  -fPIC
> >>> -I/home/yann/grass_dev/grass_yann/dist.i686-pc-linux-gnu/include
> >>> -D_FILE_OFFSET_BITS=64  -DPACKAGE=\""grasslibs"\"
> >>> -I/home/yann/grass_dev/grass_yann/dist.i686-pc-linux-gnu/include -o
> >>> OBJ.i686-pc-linux-gnu/house.o -c house.c
> >>> house.c: In function ‘house’:
> >>> house.c:10:6: internal compiler error: in rewrite_use_nonlinear_expr,
> at
> >>> tree-ssa-loop-ivopts.c:6215
> >>> Please submit a full bug report,
> >>> with preprocessed source if appropriate.
> >>> See <file:///usr/share/doc/gcc-4.7/README.Bugs> for instructions.
> >>> Preprocessed source stored into /tmp/cchZKfp8.out file, please attach
> this
> >>> to your bugreport.
> >>> Anybody under similar condition?
> >> Yes. Did you solved the problem? I suppose that the problem is in
> >> GRASS configuration or packages not in GCC...
> >> Using Linux Mint 15.
> > I just realized that grass-devel rep is only for 64bit, the
> > compilation problem is on 32bit machine. Can be there some relation?
> >> Vaclav
> >>> _______________________________________________
> >>> grass-dev mailing list
> >>> grass-dev at lists.osgeo.org
> >>> http://lists.osgeo.org/mailman/listinfo/grass-dev
Regards,
   Rashad
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20130621/9dd5755e/attachment.html>
