[GRASS-dev] problem with house.c and GCC-4.7
Vaclav Petras wenzeslaus at gmail.com
Fri Jun 21 12:24:11 PDT 2013
On 21 June 2013 18:57, Rashad M <mohammedrashadkm at gmail.com> wrote:
> Did any one have solution?. I also got same error on lauchpad build for
> raring 32bit. But both i386 and amd64 build for precise came clean.
No. I would suggest to do the bug report for GCC (e.g. at launchpad).
I cannot do it easily since don't have access to that machine anymore
but you can probably try. Following the instruction in the error
message it should be clear what to do.
Maybe it is worth to try the new/latest version of GCC, according to
some ticked I saw somewhere, there were some changes in
rewrite_use_nonlinear_expr function. But I don't know what you can do
on launchpad.
> You can see full log here [1]
> [1]
> https://launchpadlibrarian.net/143047971/buildlog_ubuntu-raring-i386.grass70_7.0.0%2B0ubuntu2%2B28630~raring1_FAILEDTOBUILD.txt.gz
> I am waiting for amd64 build and let me see if the problem comes with only
> 32 bit as Vaclav pointed out
> PS: If you have problem viewing this link please let me know
> On Thu, Jun 20, 2013 at 4:45 PM, Yann Chemin <ychemin at gmail.com> wrote:
>> I have not had that problem after upgrading the machine...
>> On 20 June 2013 15:38, Vaclav Petras <wenzeslaus at gmail.com> wrote:
>> > On 20 June 2013 11:44, Vaclav Petras <wenzeslaus at gmail.com> wrote:
>> >> Hi Yann,
>> >> On 27 May 2013 09:51, Yann Chemin <ychemin at gmail.com> wrote:
>> >>> Hi
>> >>> Using Ubuntu 13.04
>> >>> gcc  -g -O2  -fPIC
>> >>> -I/home/yann/grass_dev/grass_yann/dist.i686-pc-linux-gnu/include
>> >>> -D_FILE_OFFSET_BITS=64  -DPACKAGE=\""grasslibs"\"
>> >>> -I/home/yann/grass_dev/grass_yann/dist.i686-pc-linux-gnu/include -o
>> >>> OBJ.i686-pc-linux-gnu/house.o -c house.c
>> >>> house.c: In function ‘house’:
>> >>> house.c:10:6: internal compiler error: in rewrite_use_nonlinear_expr,
>> >>> at
>> >>> tree-ssa-loop-ivopts.c:6215
>> >>> Please submit a full bug report,
>> >>> with preprocessed source if appropriate.
>> >>> See <file:///usr/share/doc/gcc-4.7/README.Bugs> for instructions.
>> >>> Preprocessed source stored into /tmp/cchZKfp8.out file, please attach
>> >>> this
>> >>> to your bugreport.
>> >>> Anybody under similar condition?
>> >> Yes. Did you solved the problem? I suppose that the problem is in
>> >> GRASS configuration or packages not in GCC...
>> >> Using Linux Mint 15.
>> > I just realized that grass-devel rep is only for 64bit, the
>> > compilation problem is on 32bit machine. Can be there some relation?
>> >> Vaclav
>> >>> _______________________________________________
>> >>> grass-dev mailing list
>> >>> grass-dev at lists.osgeo.org
>> >>> http://lists.osgeo.org/mailman/listinfo/grass-dev
> Regards,
>    Rashad
