[GRASS-dev] [GRASS GIS] #1889: wxPy loc'n wiz: don't auto-launch into PERMANENT
    trac at osgeo.org
    Sun Mar 10 03:08:14 PDT 2013
 Reporter:  hamish           |       Owner:  grass-dev@…
     Type:  defect           |      Status:  new
 Priority:  blocker          |   Milestone:  6.4.3
Component:  wxGUI            |     Version:  6.4.3 RCs
 Keywords:  location wizard  |    Platform:  Unspecified
      Cpu:  x86-64           |
Comment(by martinl):
 Replying to [comment:14 hamish]:
 > not before it has been ported to all branches. (please don't do
 development work in the release branch and then not sync with the dev
 branches. The release branch must be treated with great care, only code
 tested in the relevant dev branch should be backported to the release
 branch- by backporting it to the release branch you're personally signing
 off that the code is tested and works. tx)
 just small note: it's probably related to the fact, that you are probably
 only developer who wants to do "development" in GRASS 6 branches. There
 were several discussions in the past, and I don't want to open this topic
 again. The result will the same. Please bear in mind, that you are
 probably only one from devs who really wants to keep `develbranch_6`
 alive. Development should be done only in trunk! Anyway this is one of
 consequences, all of us need to maintain three branches just because we
 didn't decided that we don't need `develbranch_6`. This is meant to open
 discussion again, it's just a reminder.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1889#comment:16>
