[GRASS-dev] [GRASS GIS] #1889: wxPy loc'n wiz: don't auto-launch into PERMANENT
GRASS GIS trac at osgeo.org
Sun Mar 10 03:37:13 PDT 2013
 Reporter:  hamish           |       Owner:  grass-dev@…
     Type:  defect           |      Status:  new
 Priority:  blocker          |   Milestone:  6.4.3
Component:  wxGUI            |     Version:  6.4.3 RCs
 Keywords:  location wizard  |    Platform:  Unspecified
      Cpu:  x86-64           |
Comment(by annakrat):
 Replying to [comment:14 hamish]:
 > not before it has been ported to all branches. (please don't do
 development work in the release branch and then not sync with the dev
 branches. The release branch must be treated with great care, only code
 tested in the relevant dev branch should be backported to the release
 branch- by backporting it to the release branch you're personally signing
 off that the code is tested and works. tx)
 Also, I did the changes first in release branch because now it's not time
 to test it elsewhere, then backport and test it again.
 Btw, this 'blocker' could have been opened a long time ago and not just
 before release.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1889#comment:17>
