[GRASS-dev] Rast_add_d_colour
Sun Dec 7 21:07:58 PST 2014
Yann Chemin wrote:
> OK, I found why I got lost in all that...
> there is no file appearing in colr/ with the rules made in the code.
Are you calling Rast_write_colors()?
Also, if the map isn't in the current mapset, the file will go into
<current mapset>/colr2/<mapset>/<map> rather than the mapset
containing the map.
