[GRASS-dev] Rast_add_d_colour
Yann Chemin ychemin at gmail.com
Sun Dec 7 21:16:39 PST 2014
Yes Glynns, that was my missing part, writing the file. .... and sleep too.
On 8 December 2014 at 10:37, Glynn Clements <glynn at gclements.plus.com>
wrote:
> Yann Chemin wrote:
> > OK, I found why I got lost in all that...
> > there is no file appearing in colr/ with the rules made in the code.
> Are you calling Rast_write_colors()?
> Also, if the map isn't in the current mapset, the file will go into
> <current mapset>/colr2/<mapset>/<map> rather than the mapset
> containing the map.
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20141208/e40c0e71/attachment.html>
