[GRASS-dev] Week 4: GRASS GIS 3D flowlines
Anna Petrášová kratochanna at gmail.com
Fri Jun 13 19:54:54 PDT 2014
Hi all,
1. What did you get done this week:
I have been working on computing flow accumulation. I have a simple version
working and a more precise way is almost ready. I also tried to support
different combination of inputs and outputs to make the module convenient
to use. More on the wiki [1]. The code is here [2].
2. What do you plan on doing next week?
I will be traveling so I expect to do mostly testing and running it on real
data. I also need to discuss further steps with mentors.
3. Are you blocked on anything?
No.
[1]
http://trac.osgeo.org/grass/wiki/GSoC/2014/ImplementationOf3DRasterFlowLine
[2] http://trac.osgeo.org/grass/browser/sandbox/annakrat
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20140613/2e774e25/attachment.html>
