[GRASS-dev] sphinx python documentation
Luca Delucchi lucadeluge at gmail.com
Tue May 27 23:53:41 PDT 2014
On 27 May 2014 14:06, Vaclav Petras <wenzeslaus at gmail.com> wrote:
> Hi Luca,
Hi Vaclav
> Yes. Sphinx for the whole lib/python (grass.*). I'm not sure if additional
> separate for PyGRASS would make sense, probably not. Then it would be nice
> to have Sphinx for GUI (gui/wxpython).
I think the same, have documentation for the whole lib/python without
separation of pygrass
> Then I would disable all Python things (lib/python and gui/wxpython, the
> later for sure) in Doxygen because especially GUI creates a mess in Doxygen.
> It seems that Doxygen does not handle well all the things about Python
> modules, packages (especially if lib/python/* is changed into grass.*) and
> other Python features.
> So than we would have tree documentations. Doxygen for C libraries, one
> Sphinx for Python libraries and one Sphinx for GUI.
I like this proposal, I could finish to work on pygrass documentation
and later start to prepare sphinx for other python library and gui
>> - could I replace doxigen instruction with sphinx instruction in
>> pygrass docstrings? (for example replace @param with :param)
> Yes. And remove the exclamation marks at the beginning of docstrings
> ("""!...). (They are just using some undocumented Doxygen feature to enable
> processing of commands instead of using verbatim text for docstrings.)
+1
>> [0] http://grass.osgeo.org/grass71/manuals/pygrass/index.html
> Nice, perhaps bit too conservative design but fits to GRASS manual nicely. I
> wish to have something similar for Doxygen but I'm afraid of maintenance
> issues.
what do you mean for "conservative design" ?
> Vaclav
ciao
Luca
http://gis.cri.fmach.it/delucchi/
www.lucadelu.org
