[GRASS-dev] Backport r.li memory allocation fixes?
Markus Neteler neteler at osgeo.org
Tue Oct 14 22:52:31 PDT 2014
On Wed, Oct 15, 2014 at 3:35 AM, Vaclav Petras <wenzeslaus at gmail.com> wrote:
> Hi Markus and others,
> I would do a backport or r61812 but I'm not sure if it works correctly. It
> seems to work and I got the same results as with the old version but I
> remember that you (Markus) had some doubts at one point. Now I actually see
> that you said you will backport it, so if you have your plan disregard this
> message.
Please backport it. It should probably also go into G6 which is almost
identical.
> I also wanted to use the things bellow to write a test but I don't know how.
Would this script give some ideas?
raster/r.li/r.li.testing_nc_asc.sh
Markus
