[GRASS-dev] Backport r.li memory allocation fixes?
Markus Metz markus.metz.giswork at gmail.com
Thu Oct 16 00:31:11 PDT 2014
On Wed, Oct 15, 2014 at 7:52 AM, Markus Neteler <neteler at osgeo.org> wrote:
> On Wed, Oct 15, 2014 at 3:35 AM, Vaclav Petras <wenzeslaus at gmail.com> wrote:
>> Hi Markus and others,
>> I would do a backport or r61812 but I'm not sure if it works correctly. It
>> seems to work and I got the same results as with the old version but I
>> remember that you (Markus) had some doubts at one point. Now I actually see
>> that you said you will backport it, so if you have your plan disregard this
>> message.
> Please backport it.
... after removing the C++ style comment in raster/r.li/r.li.daemon/avl.c.
Markus M
> It should probably also go into G6 which is almost
> identical.
>> I also wanted to use the things bellow to write a test but I don't know how.
> Would this script give some ideas?
> raster/r.li/r.li.testing_nc_asc.sh
> Markus
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
