[GRASS-dev] G7: how to get rid of multiple listing of identical map names?
Vaclav Petras wenzeslaus at gmail.com
Tue Sep 9 13:35:08 PDT 2014
On Mon, Sep 8, 2014 at 6:06 PM, Glynn Clements <glynn at gclements.plus.com>
wrote:
> Glynn Clements wrote:
> > But there's a rather more fundamental issue here: if G_find_file() is
> > called for an element which isn't guaranteed to exist for every map,
> > it will "find" the first map which actually contains that element,
> > which isn't necessarily the same map as for the other elements.
> > This doesn't affect the primary components of a map, because
> > Rast_open_old() first determines the mapset, then passes an explicit
> > mapset to the various G_open_* functions.
> > So, I think that G_find_file() etc should only be used in "find mode"
> > (with an empty mapset) for the "primary" element of a map (i.e.
> > "cellhd" for raster maps, the map directory for vector maps). Other
> > components should be located by first finding the mapset, then using
> > the mapset to locate any additional components.
> Fixed (hopefully) in r61840.
It seems that r61840 breaks a lot of tests. The yesterdays version (which
is by chance r61839) is working. There are errors like
ERROR: Raster map <elevation> not found
for example for g.region and r.info.
http://fatra.cnr.ncsu.edu/grassgistests/reports_for_date-2014-09-08-07-00/report_for_nc_spm_08_grass7_nc/testfiles.html
http://fatra.cnr.ncsu.edu/grassgistests/reports_for_date-2014-09-09-07-00/report_for_nc_spm_08_grass7_nc/testfiles.html
http://fatra.cnr.ncsu.edu/grassgistests/reports_for_date-2014-09-09-07-00/report_for_nc_spm_08_grass7_nc/raster/r.slope.aspect/test_r_slope_aspect/index.html
> This change also reduces the number of warnings; a warning is only
> generated when searching for the primary element.
> Given that it's a fairly fundamental change, it should be tested.
> OTOH, given that it fixes a fairly fundamental bug, it should go into
> at least one beta prior to any final release.
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20140909/ed68ec70/attachment.html>
