[GRASS-dev] OSX 10.11 Compiling
Carlos Grohmann carlos.grohmann at gmail.com
Thu Aug 6 08:06:47 PDT 2015
Yes,
worked fine now.
thanks
Carlos
On Thu, Aug 6, 2015 at 10:49 AM, Rainer M Krug <Rainer at krugs.de> wrote:
> Thanks to Glenn, this should be working now:
> --8<---------------cut here---------------start------------->8---
> brew install -build-from-source liblas
> brew install --with-liblas HEAD grass-71
> --8<---------------cut here---------------end--------------->8---
> I also updated the wiki at
> http://grasswiki.osgeo.org/wiki/Compiling_on_MacOSX_using_homebrew#How_to_install_GRASS_GIS_7.1_SVN_Head
> Cheers,
> Rainer
> Rainer M Krug <Rainer at krugs.de> writes:
> > OK - I tried the installation of grass 70 from osgeo4mac and it has the
> > same error. I have reported it on their website (see
> > https://github.com/OSGeo/homebrew-osgeo4mac/issues/102)
> > So it is not a 7.1 issue.
> > Cheers,
> > Rainer
> >> Carlos Grohmann <carlos.grohmann at gmail.com> writes:
> >>> Hi
> >>> I never installed OS X on a virtual machine, can't help much there..
> (I'm
> >>> using yosemite as primary machine and El Capitan on a secondary one)
> >> OK - I will see how it goes. Maybe a second HDD is the easiest option.
> >>> While we are here, I tried the homebrew tap for 7.1svn on a Yosemite
> >>> machine and it didn't worked.
> >> Could you give me the options you used for
> >> | brew install --HEAD grass-71
> >> so that I can check? because on Travis-ci the default installation is
> >> installing without errors - I am trying it just now at
> >> https://travis-ci.org/rkrug/homebrew-experimental
> >>> First I tried to install with libLas, add although it installed libels
> >>> correctly, it can't find the library when running GRASS'configure
> >>> :==> ./configure --prefix=/usr/local/Cellar/grass-71/HEAD
> --enable-shared
> >>> --with-
> >>> checking for gdal-config... /usr/local/opt/gdal/bin/gdal-config
> >>> rm: conftest.dSYM: is a directory
> >>> checking whether to use libLAS... yes
> >>> checking for liblas-config... /usr/local/opt/liblas/bin/liblas-config
> >>> configure: error: *** Unable to locate libLAS library.
> >>> Then I tried with libels and it went OK, but when I run:
> >>> Serenity:~ guano$ /usr/local/bin/grass71
> >>> Traceback (most recent call last):
> >>>   File "/usr/local/bin/grass71", line 54, in <module>
> >>>     ENCODING = locale.getdefaultlocale()[1]
> >>>   File
> "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/locale.py",
> >>> line 511, in getdefaultlocale
> >>>     return _parse_localename(localename)
> >>>   File
> >>> line 443, in _parse_localename
> >>>     raise ValueError, 'unknown locale: %s' % localename
> >>> ValueError: unknown locale: UTF-8
> >>> Serenity:~ guano$
> >> I have everything (including python) in homebrew and I can install it,
> >> although I have not tested any additional options.
> >> I just added two more test cases / envelopes on travis-ci (--with-liblas
> >> and --with-openblas) to test this and they are running at the moment ...
> >> You can see them at
> >> https://travis-ci.org/rkrug/homebrew-experimental/builds/74242734
> >> And the --with-liblas fails there as well. OK.
> >> I added the -v for the v=compile to get a better picture ...
> >> https://travis-ci.org/rkrug/homebrew-experimental/builds/74248159
> >> same errors.
> >> I found the following:
> >> grass70 not detecting latest source build of libLAS (1.7.0)
> >> https://trac.osgeo.org/grass/ticket/2065
> >> And the only reference I see is that liblas newer than 1.7 is
> >> installed, but homebrew installs 1.8 - so this is not the problem.
> >> OK - I think I narrowed it down: it seems that the problem is gdal.
> >> I will open another subject with this.
> >> Cheers,
> >> Rainer
> >>> any ideas?
> >>> thanks
> >>> Carlos
> >>> On Tue, Aug 4, 2015 at 10:52 AM, Rainer M Krug <Rainer at krugs.de>
> >>>> > Hello Rainer (and devs)
> >>>> > I think you only need to join the beta program (although I have the
> free
> >>>> > developer account, just to be able to download xcode-related tools
> like
> >>>> the
> >>>> > comand line tools).
> >>>> Thanks - I registered for the beta program an I am downloading El
> >>>> Capitan at the moment.
> >>>> Can you give any pointers how I can install it in Virtual Box as I do
> >>>> not want to interfere with my production machine and do prefer the
> >>>> flexibility of a virtual machine.
> >>>> I'll take a look at the errors when I have it installed - which might
> be
> >>>> in two weeks time as I will be on holiday next week.
> >>>> Thanks,
> >>>> Rainer
> >>>> > I'll summarise what I know so far about these issues:
> >>>> > - When compiling, I get a lot of errors. These are related to
> creating
> >>>> html
> >>>> > docs. As Glynn said, at this pint of compilation, the module is run
> >>>> > with  --html-description
> >>>> > switch to get a list of its options. Any problems with wxpython will
> >>>> cause
> >>>> > an error here.
> >>>> > - Running make in the module directory show a call to
> >>>> > libgrass_gis.7.0.1svn.dylib,
> >>>> > but with the wrong path. It tries to load the library from the final
> >>>> > package path (after installation), which doesn't exists yet..
> >>>> > see the last lines of this output:
> >>>> > cd scripts/d.correlate/
> >>>> > GuanoAFBIOTA:d.correlate guano$ make
> >>>> > if [
> "/Users/guano/Documents/installs/grass70_release/dist.x86_64-apple-darwin15.0.0/scripts/d.correlate"
> >>>> > != "" ] ; then
> GISRC=/Users/guano/Documents/installs/grass70_release/dist.x86_64-apple-darwin15.0.0/demolocation/.grassrc70
> GISBASE=/Users/guano/Documents/installs/grass70_release/dist.x86_64-apple-darwin15.0.0
> PATH="/Users/guano/Documents/installs/grass70_release/dist.x86_64-apple-darwin15.0.0/bin:/Users/guano/Documents/installs/grass70_release/dist.x86_64-apple-darwin15.0.0/bin:/Users/guano/Documents/installs/grass70_release/dist.x86_64-apple-darwin15.0.0/scripts:$PATH"
> PYTHONPATH="/Users/guano/Documents/installs/grass70_release/dist.x86_64-apple-darwin15.0.0/etc/python:/Users/guano/Documents/installs/grass70_release/dist.x86_64-apple-darwin15.0.0/gui/wxpython:$PYTHONPATH"
> DYLD_LIBRARY_PATH="/Users/guano/Documents/installs/grass70_release/dist.x86_64-apple-darwin15.0.0/bin:/Users/guano/Documents/installs/grass70_release/dist.x86_64-apple-darwin15.0.0/scripts:/Users/guano/Documents/installs/grass70_release/dist.x86_64-apple-darwin15.0.0/lib:/Users/guano/Documents/installs/grass70_release/dist.x86_64-apple-darwin15.0.0/lib:"
> >>>> > LC_ALL=C
> >>>> > --html-description < /dev/null | grep -v '</body>\|</html>' >
> >>>> > d.correlate.tmp.html ; fi
> >>>> > dyld: Library not loaded:
> /Applications/GRASS-7.0.app/Contents/MacOS/lib/libgrass_gis.7.0.1svn.dylib
> >>>> >   Referenced from:
> /Users/guano/Documents/installs/grass70_release/dist.x86_64-apple-darwin15.0.0/bin/g.parser
> >>>> >   Reason: image not found
> >>>> > make: *** [d.correlate.tmp.html] Error 1
> >>>> > rm d.correlate.tmp.html
> >>>> > - Ignoring the error and creating the package will work, and the
> package
> >>>> > will install, although when run, the GUI will fail:
> >>>> >>>> from grass.pygrass import messages
> >>>> >   File "<stdin>", line 1, in <module>
> >>>> >   File
> "/Applications/GRASS-7.0.app/Contents/MacOS/etc/python/grass/pygrass/messages/__init__.py",
> >>>> > line 19, in <module>
> >>>> >     import grass.lib.gis as libgis
> >>>> >   File
> "/Applications/GRASS-7.0.app/Contents/MacOS/etc/python/grass/lib/gis.py",
> >>>> > line 23, in <module>
> >>>> >     _libs["grass_gis.7.0.1RC2"] = load_library("grass_gis.7.0.1RC2")
> >>>> >   File
> "/Applications/GRASS-7.0.app/Contents/MacOS/etc/python/grass/lib/ctypes_loader.py",
> >>>> > line 57, in load_library
> >>>> >     raise ImportError,"%s not found." % libname
> >>>> > ImportError: grass_gis.7.0.1RC2 not found.
> >>>> > cheers
> >>>> > Carlos
> >>>> > On Sun, Aug 2, 2015 at 7:51 AM, Rainer M Krug <r.m.krug at gmail.com>
> >>>> wrote:
> >>>> >> Envoyé de mon iPhone
> >>>> >> Le 31 juil. 2015 à 23:07, Carlos Grohmann <
> carlos.grohmann at gmail.com> a
> >>>> >> écrit :
> >>>> >> Hi
> >>>> >> The homebrew formula doesn't really work on OSX 10.11 beta. In the
> log
> >>>> >> file (attached) I can see the same errors in compilation I got when
> >>>> tried
> >>>> >> to compile svn. They are related to html manual pages, but prevent
> >>>> >> installation from continue.
> >>>> >> As I do not have 10.11 beta I can't check it. But please let me
> (and
> >>>> >> osgeo4mac) know when you found a solution as I think it will also
> affect
> >>>> >> 6.4x and 7.0x versions.
> >>>> >> Do I have to have a developer account with apple to have access to
> the
> >>>> >> beta?
> >>>> >> Cheers
> >>>> >> Rainer
> >>>> >> Carlos
> >>>> >> brew tap rkrug/head-only
> >>>> >> ==> Tapping rkrug/head-only
> >>>> >> Cloning into '/usr/local/Library/Taps/rkrug/homebrew-head-only'...
> >>>> >> remote: Counting objects: 4, done.
> >>>> >> remote: Compressing objects: 100% (4/4), done.
> >>>> >> remote: Total 4 (delta 0), reused 4 (delta 0), pack-reused 0
> >>>> >> Unpacking objects: 100% (4/4), done.
> >>>> >> Checking connectivity... done.
> >>>> >> Tapped 1 formula (27 files, 116K)
> >>>> >> brew install grass-71
> >>>> >> Error: rkrug/head-only/grass-71 is a head-only formula
> >>>> >> Install with `brew install --HEAD rkrug/head-only/grass-71`
> >>>> >> Warning: You are using OS X 10.11.
> >>>> >> We do not provide support for this pre-release version.
> >>>> >> You may encounter build failures or other breakage.
> >>>> >> ==> Installing grass-71 from rkrug/homebrew-head-only
> >>>> >> Error: No available formula for nc_spm_08_grass7 (dependency of
> >>>> >> rkrug/head-only/grass-71)
> >>>> >> guano$ brew install --HEAD rkrug/head-only/grass-71
> >>>> >> --without-nc_spm_08_grass7
> >>>> >> ==> Cloning https://svn.osgeo.org/grass/grass/trunk
> >>>> >> Updating /Library/Caches/Homebrew/grass-71--svn-HEAD
> >>>> >> ==> Patching
> >>>> >> patching file include/Make/Install.make
> >>>> >> Hunk #1 succeeded at 116 (offset 2 lines).
> --enable-shared
> >>>> >> --with-
> >>>> >> ==> make GDAL_DYNAMIC=
> >>>> >> appear in the error log. If you get an error building a library,
> you
> >>>> will
> >>>> >> also get errors from anything which uses the library.
> >>>> >> Finished compilation: Fri Jul 31 17:36:12 BRT 2015
> >>>> >> make: *** [default] Error 1
> >>>> >> READ THIS: https://git.io/brew-troubleshooting
> >>>> >> If reporting this issue please do so at (not Homebrew/homebrew):
> >>>> >>   https://github.com/rkrug/homebrew-head-only/issues
> >>>> >> GuanoAFBIOTA:~ guano$
> >>>> >> On Fri, Jul 31, 2015 at 11:54 AM, Carlos Grohmann <
> >>>> >> carlos.grohmann at gmail.com> wrote:
> >>>> >>> Very interesting!
> >>>> >>> From the brew recipe, it looks that one needs all dependencies
> >>>> installed
> >>>> >>> via homebrew, is that right? I'm thinking that most will have
> >>>> Kyngsburie's
> >>>> >>> Frameworks already installed (at least GDAL). Same goes for
> wx-python.
> >>>> >>> best
> >>>> >>> Carlos
> >>>> >>> On Fri, Jul 31, 2015 at 5:44 AM, Rainer M Krug <Rainer at krugs.de>
> >>>> wrote:
> >>>> >>>> Anna Petrášová <kratochanna at gmail.com> writes:
> >>>> >>>> > On Thu, Jul 30, 2015 at 6:38 AM, Rainer M Krug <
> Rainer at krugs.de>
> >>>> >>>> wrote:
> >>>> >>>> >> Hi
> >>>> >>>> >> I just added a section / new page in the WIKI for
> installation of
> >>>> >>>> GRASS
> >>>> >>>> >> using homebrew. Please see
> >>>> >>>> >> http://grasswiki.osgeo.org/wiki/Compile_and_Install#Mac_OSX
> >>>> >>>> >> and
> >>>> >>>> >> It would be great if some Mac / homebrew users would see if it
> >>>> works
> >>>> >>>> and
> >>>> >>>> >> give me comments here.
> >>>> >>>> > I will try to test it next week. Thank you for your efforts!
> >>>> >>>> Great - let me know how it goes, although I don't know if I will
> be
> >>>> able
> >>>> >>>> to reply as I am away and possibly only have very limited
> internet
> >>>> >>>> access.
> >>>> >>>> Thanks,
> >>>> >>>> Rainer
> >>>> >>>> > Anna
> >>>> >>>> >> Cheers,
> >>>> >>>> >> Rainer
> >>>> >>>> >> Rainer M. Krug, PhD (Conservation Ecology, SUN), MSc
> (Conservation
> >>>> >>>> >> Biology, UCT), Dipl. Phys. (Germany)
> >>>> >>>> >> Centre of Excellence for Invasion Biology
> >>>> >>>> >> Stellenbosch University
> >>>> >>>> >> South Africa
> >>>> >>>> >> Tel :       +33 - (0)9 53 10 27 44
> >>>> >>>> >> Cell:       +33 - (0)6 85 62 59 98
> >>>> >>>> >> Fax :       +33 - (0)9 58 10 27 44
> >>>> >>>> >> Fax (D):    +49 - (0)3 21 21 25 22 44
> >>>> >>>> >> email:      Rainer at krugs.de
> >>>> >>>> >> Skype:      RMkrug
> >>>> >>>> >> PGP: 0x0F52F982
> >>>> >>>> >> _______________________________________________
> >>>> >>>> >> grass-dev mailing list
> >>>> >>>> >> grass-dev at lists.osgeo.org
> >>>> >>>> >> http://lists.osgeo.org/mailman/listinfo/grass-dev
> (Conservation
> >>>> >>>> South Africa
> >>>> >>>> Skype:      RMkrug
> >>>> >>>> PGP: 0x0F52F982
> >>>> >>> Prof. Carlos Henrique Grohmann
> >>>> >>> Institute of Energy and Environment - Univ. of São Paulo, Brazil
> >>>> >>> - Digital Terrain Analysis | GIS | Remote Sensing -
> >>>> >>> http://carlosgrohmann.com
> >>>> >>> http://orcid.org/0000-0001-5073-5572
> >>>> >>> ________________
> >>>> >>> Can’t stop the signal.
> >>>> >> ________________
> >>>> >> <02.make>
> >>>> Rainer M. Krug, PhD (Conservation Ecology, SUN), MSc (Conservation
> >>>> South Africa
> >>>> Skype:      RMkrug
> >>>> PGP: 0x0F52F982
> South Africa
> Skype:      RMkrug
> PGP: 0x0F52F982
________________
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20150806/e8a96301/attachment-0001.html>
