[GRASS-dev] OSX 10.11 Compiling
Rainer M Krug Rainer at krugs.de
Thu Aug 6 08:24:27 PDT 2015
Carlos Grohmann <carlos.grohmann at gmail.com> writes:
> Yes,
> worked fine now.
Great
Rainer
> thanks
> Carlos
> On Thu, Aug 6, 2015 at 10:49 AM, Rainer M Krug <Rainer at krugs.de> wrote:
>> Thanks to Glenn, this should be working now:
>> --8<---------------cut here---------------start------------->8---
>> brew install -build-from-source liblas
>> brew install --with-liblas HEAD grass-71
>> --8<---------------cut here---------------end--------------->8---
>> I also updated the wiki at
>> http://grasswiki.osgeo.org/wiki/Compiling_on_MacOSX_using_homebrew#How_to_install_GRASS_GIS_7.1_SVN_Head
>> Cheers,
>> Rainer
>> Rainer M Krug <Rainer at krugs.de> writes:
>> > OK - I tried the installation of grass 70 from osgeo4mac and it has the
>> > same error. I have reported it on their website (see
>> > https://github.com/OSGeo/homebrew-osgeo4mac/issues/102)
>> > So it is not a 7.1 issue.
>> > Cheers,
>> > Rainer
>> >>> Hi
>> >>> I never installed OS X on a virtual machine, can't help much there..
>> (I'm
>> >>> using yosemite as primary machine and El Capitan on a secondary one)
>> >> OK - I will see how it goes. Maybe a second HDD is the easiest option.
>> >>> While we are here, I tried the homebrew tap for 7.1svn on a Yosemite
>> >>> machine and it didn't worked.
>> >> Could you give me the options you used for
>> >> | brew install --HEAD grass-71
>> >> so that I can check? because on Travis-ci the default installation is
>> >> installing without errors - I am trying it just now at
>> >> https://travis-ci.org/rkrug/homebrew-experimental
>> >>> First I tried to install with libLas, add although it installed libels
>> >>> correctly, it can't find the library when running GRASS'configure
>> >>> :==> ./configure --prefix=/usr/local/Cellar/grass-71/HEAD
>> --enable-shared
>> >>> --with-
>> >>> checking for gdal-config... /usr/local/opt/gdal/bin/gdal-config
>> >>> rm: conftest.dSYM: is a directory
>> >>> checking whether to use libLAS... yes
>> >>> checking for liblas-config... /usr/local/opt/liblas/bin/liblas-config
>> >>> configure: error: *** Unable to locate libLAS library.
>> >>> Then I tried with libels and it went OK, but when I run:
>> >>> Serenity:~ guano$ /usr/local/bin/grass71
>> >>> Traceback (most recent call last):
>> >>>   File "/usr/local/bin/grass71", line 54, in <module>
>> >>>     ENCODING = locale.getdefaultlocale()[1]
>> >>>   File
>> "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/locale.py",
>> >>> line 511, in getdefaultlocale
>> >>>     return _parse_localename(localename)
>> >>>   File
>> >>> line 443, in _parse_localename
>> >>>     raise ValueError, 'unknown locale: %s' % localename
>> >>> ValueError: unknown locale: UTF-8
>> >>> Serenity:~ guano$
>> >> I have everything (including python) in homebrew and I can install it,
>> >> although I have not tested any additional options.
>> >> I just added two more test cases / envelopes on travis-ci (--with-liblas
>> >> and --with-openblas) to test this and they are running at the moment ...
>> >> You can see them at
>> >> https://travis-ci.org/rkrug/homebrew-experimental/builds/74242734
>> >> And the --with-liblas fails there as well. OK.
>> >> I added the -v for the v=compile to get a better picture ...
>> >> https://travis-ci.org/rkrug/homebrew-experimental/builds/74248159
>> >> same errors.
>> >> I found the following:
>> >> grass70 not detecting latest source build of libLAS (1.7.0)
>> >> https://trac.osgeo.org/grass/ticket/2065
>> >> And the only reference I see is that liblas newer than 1.7 is
>> >> installed, but homebrew installs 1.8 - so this is not the problem.
>> >> OK - I think I narrowed it down: it seems that the problem is gdal.
>> >> I will open another subject with this.
>> >> Cheers,
>> >> Rainer
>> >>> any ideas?
>> >>> thanks
>> >>> Carlos
>> >>> On Tue, Aug 4, 2015 at 10:52 AM, Rainer M Krug <Rainer at krugs.de>
>> >>>> > Hello Rainer (and devs)
>> >>>> > I think you only need to join the beta program (although I have the
>> free
>> >>>> > developer account, just to be able to download xcode-related tools
>> like
>> >>>> the
>> >>>> > comand line tools).
>> >>>> Thanks - I registered for the beta program an I am downloading El
>> >>>> Capitan at the moment.
>> >>>> Can you give any pointers how I can install it in Virtual Box as I do
>> >>>> not want to interfere with my production machine and do prefer the
>> >>>> flexibility of a virtual machine.
>> >>>> I'll take a look at the errors when I have it installed - which might
>> be
>> >>>> in two weeks time as I will be on holiday next week.
>> >>>> Thanks,
>> >>>> Rainer
>> >>>> > I'll summarise what I know so far about these issues:
>> >>>> > - When compiling, I get a lot of errors. These are related to
>> creating
>> >>>> html
>> >>>> > docs. As Glynn said, at this pint of compilation, the module is run
>> >>>> > with  --html-description
>> >>>> > switch to get a list of its options. Any problems with wxpython will
>> >>>> cause
>> >>>> > an error here.
>> >>>> > - Running make in the module directory show a call to
>> >>>> > libgrass_gis.7.0.1svn.dylib,
>> >>>> > but with the wrong path. It tries to load the library from the final
>> >>>> > package path (after installation), which doesn't exists yet..
>> >>>> > see the last lines of this output:
>> >>>> > cd scripts/d.correlate/
>> >>>> > GuanoAFBIOTA:d.correlate guano$ make
>> >>>> > if [
>> "/Users/guano/Documents/installs/grass70_release/dist.x86_64-apple-darwin15.0.0/scripts/d.correlate"
>> >>>> > != "" ] ; then
>> GISRC=/Users/guano/Documents/installs/grass70_release/dist.x86_64-apple-darwin15.0.0/demolocation/.grassrc70
>> GISBASE=/Users/guano/Documents/installs/grass70_release/dist.x86_64-apple-darwin15.0.0
>> PATH="/Users/guano/Documents/installs/grass70_release/dist.x86_64-apple-darwin15.0.0/bin:/Users/guano/Documents/installs/grass70_release/dist.x86_64-apple-darwin15.0.0/bin:/Users/guano/Documents/installs/grass70_release/dist.x86_64-apple-darwin15.0.0/scripts:$PATH"
>> PYTHONPATH="/Users/guano/Documents/installs/grass70_release/dist.x86_64-apple-darwin15.0.0/etc/python:/Users/guano/Documents/installs/grass70_release/dist.x86_64-apple-darwin15.0.0/gui/wxpython:$PYTHONPATH"
>> DYLD_LIBRARY_PATH="/Users/guano/Documents/installs/grass70_release/dist.x86_64-apple-darwin15.0.0/bin:/Users/guano/Documents/installs/grass70_release/dist.x86_64-apple-darwin15.0.0/scripts:/Users/guano/Documents/installs/grass70_release/dist.x86_64-apple-darwin15.0.0/lib:/Users/guano/Documents/installs/grass70_release/dist.x86_64-apple-darwin15.0.0/lib:"
>> >>>> > LC_ALL=C
>> >>>> > --html-description < /dev/null | grep -v '</body>\|</html>' >
>> >>>> > d.correlate.tmp.html ; fi
>> >>>> > dyld: Library not loaded:
>> /Applications/GRASS-7.0.app/Contents/MacOS/lib/libgrass_gis.7.0.1svn.dylib
>> >>>> >   Referenced from:
>> /Users/guano/Documents/installs/grass70_release/dist.x86_64-apple-darwin15.0.0/bin/g.parser
>> >>>> >   Reason: image not found
>> >>>> > make: *** [d.correlate.tmp.html] Error 1
>> >>>> > rm d.correlate.tmp.html
>> >>>> > - Ignoring the error and creating the package will work, and the
>> package
>> >>>> > will install, although when run, the GUI will fail:
>> >>>> >>>> from grass.pygrass import messages
>> >>>> >   File "<stdin>", line 1, in <module>
>> >>>> >   File
>> "/Applications/GRASS-7.0.app/Contents/MacOS/etc/python/grass/pygrass/messages/__init__.py",
>> >>>> > line 19, in <module>
>> >>>> >     import grass.lib.gis as libgis
>> >>>> >   File
>> "/Applications/GRASS-7.0.app/Contents/MacOS/etc/python/grass/lib/gis.py",
>> >>>> > line 23, in <module>
>> >>>> >     _libs["grass_gis.7.0.1RC2"] = load_library("grass_gis.7.0.1RC2")
>> >>>> >   File
>> "/Applications/GRASS-7.0.app/Contents/MacOS/etc/python/grass/lib/ctypes_loader.py",
>> >>>> > line 57, in load_library
>> >>>> >     raise ImportError,"%s not found." % libname
>> >>>> > ImportError: grass_gis.7.0.1RC2 not found.
>> >>>> > cheers
>> >>>> > Carlos
>> >>>> > On Sun, Aug 2, 2015 at 7:51 AM, Rainer M Krug <r.m.krug at gmail.com>
>> >>>> wrote:
>> >>>> >> Envoyé de mon iPhone
>> >>>> >> Le 31 juil. 2015 à 23:07, Carlos Grohmann <
>> carlos.grohmann at gmail.com> a
>> >>>> >> écrit :
>> >>>> >> Hi
>> >>>> >> The homebrew formula doesn't really work on OSX 10.11 beta. In the
>> log
>> >>>> >> file (attached) I can see the same errors in compilation I got when
>> >>>> tried
>> >>>> >> to compile svn. They are related to html manual pages, but prevent
>> >>>> >> installation from continue.
>> >>>> >> As I do not have 10.11 beta I can't check it. But please let me
>> (and
>> >>>> >> osgeo4mac) know when you found a solution as I think it will also
>> affect
>> >>>> >> 6.4x and 7.0x versions.
>> >>>> >> Do I have to have a developer account with apple to have access to
>> the
>> >>>> >> beta?
>> >>>> >> Cheers
>> >>>> >> Rainer
>> >>>> >> Carlos
>> >>>> >> brew tap rkrug/head-only
>> >>>> >> ==> Tapping rkrug/head-only
>> >>>> >> Cloning into '/usr/local/Library/Taps/rkrug/homebrew-head-only'...
>> >>>> >> remote: Counting objects: 4, done.
>> >>>> >> remote: Compressing objects: 100% (4/4), done.
>> >>>> >> remote: Total 4 (delta 0), reused 4 (delta 0), pack-reused 0
>> >>>> >> Unpacking objects: 100% (4/4), done.
>> >>>> >> Checking connectivity... done.
>> >>>> >> Tapped 1 formula (27 files, 116K)
>> >>>> >> brew install grass-71
>> >>>> >> Error: rkrug/head-only/grass-71 is a head-only formula
>> >>>> >> Install with `brew install --HEAD rkrug/head-only/grass-71`
>> >>>> >> Warning: You are using OS X 10.11.
>> >>>> >> We do not provide support for this pre-release version.
>> >>>> >> You may encounter build failures or other breakage.
>> >>>> >> ==> Installing grass-71 from rkrug/homebrew-head-only
>> >>>> >> Error: No available formula for nc_spm_08_grass7 (dependency of
>> >>>> >> rkrug/head-only/grass-71)
>> >>>> >> guano$ brew install --HEAD rkrug/head-only/grass-71
>> >>>> >> --without-nc_spm_08_grass7
>> >>>> >> ==> Cloning https://svn.osgeo.org/grass/grass/trunk
>> >>>> >> Updating /Library/Caches/Homebrew/grass-71--svn-HEAD
>> >>>> >> ==> Patching
>> >>>> >> patching file include/Make/Install.make
>> >>>> >> Hunk #1 succeeded at 116 (offset 2 lines).
>> --enable-shared
>> >>>> >> --with-
>> >>>> >> ==> make GDAL_DYNAMIC=
>> >>>> >> appear in the error log. If you get an error building a library,
>> you
>> >>>> will
>> >>>> >> also get errors from anything which uses the library.
>> >>>> >> Finished compilation: Fri Jul 31 17:36:12 BRT 2015
>> >>>> >> make: *** [default] Error 1
>> >>>> >> READ THIS: https://git.io/brew-troubleshooting
>> >>>> >> If reporting this issue please do so at (not Homebrew/homebrew):
>> >>>> >>   https://github.com/rkrug/homebrew-head-only/issues
>> >>>> >> GuanoAFBIOTA:~ guano$
>> >>>> >> On Fri, Jul 31, 2015 at 11:54 AM, Carlos Grohmann <
>> >>>> >> carlos.grohmann at gmail.com> wrote:
>> >>>> >>> Very interesting!
>> >>>> >>> From the brew recipe, it looks that one needs all dependencies
>> >>>> installed
>> >>>> >>> via homebrew, is that right? I'm thinking that most will have
>> >>>> Kyngsburie's
>> >>>> >>> Frameworks already installed (at least GDAL). Same goes for
>> wx-python.
>> >>>> >>> best
>> >>>> >>> Carlos
>> >>>> >>> On Fri, Jul 31, 2015 at 5:44 AM, Rainer M Krug <Rainer at krugs.de>
>> >>>> wrote:
>> >>>> >>>> Anna Petrášová <kratochanna at gmail.com> writes:
>> >>>> >>>> > On Thu, Jul 30, 2015 at 6:38 AM, Rainer M Krug <
>> Rainer at krugs.de>
>> >>>> >>>> wrote:
>> >>>> >>>> >> Hi
>> >>>> >>>> >> I just added a section / new page in the WIKI for
>> installation of
>> >>>> >>>> GRASS
>> >>>> >>>> >> using homebrew. Please see
>> >>>> >>>> >> http://grasswiki.osgeo.org/wiki/Compile_and_Install#Mac_OSX
>> >>>> >>>> >> and
>> >>>> >>>> >> It would be great if some Mac / homebrew users would see if it
>> >>>> works
>> >>>> >>>> and
>> >>>> >>>> >> give me comments here.
>> >>>> >>>> > I will try to test it next week. Thank you for your efforts!
>> >>>> >>>> Great - let me know how it goes, although I don't know if I will
>> be
>> >>>> able
>> >>>> >>>> to reply as I am away and possibly only have very limited
>> internet
>> >>>> >>>> access.
>> >>>> >>>> Thanks,
>> >>>> >>>> Rainer
>> >>>> >>>> > Anna
>> >>>> >>>> >> Cheers,
>> >>>> >>>> >> Rainer
>> >>>> >>>> >> Rainer M. Krug, PhD (Conservation Ecology, SUN), MSc
>> (Conservation
>> >>>> >>>> >> Biology, UCT), Dipl. Phys. (Germany)
>> >>>> >>>> >> Centre of Excellence for Invasion Biology
>> >>>> >>>> >> Stellenbosch University
>> >>>> >>>> >> South Africa
>> >>>> >>>> >> Tel :       +33 - (0)9 53 10 27 44
>> >>>> >>>> >> Cell:       +33 - (0)6 85 62 59 98
>> >>>> >>>> >> Fax :       +33 - (0)9 58 10 27 44
>> >>>> >>>> >> Fax (D):    +49 - (0)3 21 21 25 22 44
>> >>>> >>>> >> email:      Rainer at krugs.de
>> >>>> >>>> >> Skype:      RMkrug
>> >>>> >>>> >> PGP: 0x0F52F982
>> >>>> >>>> >> _______________________________________________
>> >>>> >>>> >> grass-dev mailing list
>> >>>> >>>> >> grass-dev at lists.osgeo.org
>> >>>> >>>> >> http://lists.osgeo.org/mailman/listinfo/grass-dev
>> (Conservation
>> >>>> >>>> South Africa
>> >>>> >>>> Skype:      RMkrug
>> >>>> >>>> PGP: 0x0F52F982
>> >>>> >>> Prof. Carlos Henrique Grohmann
>> >>>> >>> Institute of Energy and Environment - Univ. of São Paulo, Brazil
>> >>>> >>> - Digital Terrain Analysis | GIS | Remote Sensing -
>> >>>> >>> http://carlosgrohmann.com
>> >>>> >>> http://orcid.org/0000-0001-5073-5572
>> >>>> >>> ________________
>> >>>> >>> Can’t stop the signal.
>> >>>> >> ________________
>> >>>> >> <02.make>
>> >>>> Rainer M. Krug, PhD (Conservation Ecology, SUN), MSc (Conservation
>> >>>> South Africa
>> >>>> Skype:      RMkrug
>> >>>> PGP: 0x0F52F982
>> South Africa
>> Skype:      RMkrug
>> PGP: 0x0F52F982
Rainer M. Krug, PhD (Conservation Ecology, SUN), MSc (Conservation Biology, UCT), Dipl. Phys. (Germany)
South Africa
Skype:      RMkrug
PGP: 0x0F52F982
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20150806/6286d9ee/attachment.pgp>
