[GRASS-dev] wxNviz issue: no visual output
Markus Neteler neteler at osgeo.org
Thu Aug 20 06:57:37 PDT 2015
On Thu, Aug 20, 2015 at 2:08 PM, Anna Petrášová <kratochanna at gmail.com> wrote:
> On Thu, Aug 20, 2015 at 7:11 AM, Markus Neteler <neteler at osgeo.org> wrote:
>> - show map in wxGUI: ok
>> - 3D view: white
>> No error message. I tried to adjust the view parameters but no way...
> I assume you wanted to display the dem with the flowacc draped over it?
Yes.
> In this case you have to switch off the flowacc layer because it's not a
> surface - you set it as color of the dem surface.
ah, right.
I guess I'll never learn that ;-)
> If you leave flowacc there, it tries to display it as a surface, but flowacc
> has crazy high values and the display can't really show it. If you tweak
> vertical ex. and height long enough you can eventually display it.
OK - in this case, could wxNVIZ print a message that "xyz map has a
too large value range to be displayed as surface"
Then I would rather immediately realize that I loaded the wrong map.
Markus
