[GRASS-dev] file option in r.series - still open files issue
Paulo van Breugel p.vanbreugel at gmail.com
Thu Dec 3 08:28:23 PST 2015
On Thu, Dec 3, 2015 at 4:42 PM, Anna Petrášová <kratochanna at gmail.com>
wrote:
> On Thu, Dec 3, 2015 at 10:26 AM, Paulo van Breugel <p.vanbreugel at gmail.com
> > wrote:
>> From the r.series manual I thought that the *file* option allows one to
>> analyze large amount of raster maps without hitting open files limit and
>> the size limit of command line arguments. Yet, when using the r.series with
>> as input a file with 994 raster layers, I am still getting an error message
>> about "too many open files"
>> GRASS 7.1.svn (Data_latlon):~ > r.series --overwrite file=a.txt
>> output=Spec_rich method=count range=1,2
>> WARNING: G__open(read): Unable to open
>> '/media/HD2/Data/GRASSdb/Data_latlon/VECEA_species/cellhd/maxent_v1_Hyparrhenia_rufa_rcp45_2055_ens_mean_wc60s_presabs':
>>          Too many open files
>> The mentioned layer is the 551th layer out of a list of 996 layers.
>> Did I misunderstood this 'file' option?
> Try to use z flag. I think the manual is wrong:
> Use the *file* option to analyze large amount of raster maps without
> hitting open files limit and the size limit of command line arguments. The
> computation is slower than the *input* option method. For every sinlge
> row in the output map(s) all input maps are opened and closed.
> Anna
The -z flag works perfectly, thanks. I though I would provide a patch with
an update of the manual page, but to do so, I need to understand it
correctly;
What I understand now is that the -z flag is to avoid the open file limit,
while the file option is to avoid the comman line size limit?
If that is true, for which (or both) the following still applies:
"The computation is slower as for every sinlge row in the
output map(s) all input maps are opened and closed. The amount of
RAM will rise linear with the number of specified input maps."
>> Paulo
>> p.s., Running GRASS GIS trunk on Linux
>> grass-dev mailing list
>> grass-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20151203/ce4955a3/attachment.html>
