[GRASS-dev] v.net.path issue report
José Anderson joseandersonbatista at gmail.com
Tue Dec 15 06:38:07 PST 2015
Hi all, I've been sharing the v.net.path issue I've experiência to the
User's list with no reply.
After trying the command in two windows versions, it seems to me it is a
GRASS core issue that should be reported.
Here is the description below.
I've tried v.net.path over a line network (one branch only) I built using "
v.net -c operation=nodes" over win7 and win8.
v.net.path cannot get finished and stays long and long showing the message
"Building graph... Registering arcs..."
I have more details as long as you ask me.
A lot of thanks.
Jose
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20151215/bc0c9454/attachment.html>
