[GRASS-dev] v.net.path issue report
Moritz Lennert mlennert at club.worldonline.be
Tue Dec 15 08:12:05 PST 2015
On 15/12/15 15:38, José Anderson wrote:
> Hi all, I've been sharing the v.net.path issue I've experiência to the
> User's list with no reply.
> After trying the command in two windows versions, it seems to me it is a
> GRASS core issue that should be reported.
> Here is the description below.
> I've tried v.net.path over a line network (one branch only) I built
> using "v.net <http://v.net> -c operation=nodes" over win7 and win8.
> v.net.path cannot get finished and stays long and long showing the
> message "Building graph... Registering arcs..."
> I have more details as long as you ask me.
Can you reproduce this with the North Carolina Demo dataset ? This would
allow others to test. Or make your data available somehow ?
Moritz
