[GRASS-dev] Vect_rewrite_line using off_t as line id
Fri Sep 18 01:29:29 PDT 2015
Radim Blazek wrote:
> Can I get from GRASS includes the real type of off_t which was used
> when GRASS was compiled?
Not easily. Or reliably. You could use the compiler switches from
Platform.make and include <grass/config.h> in the hope that it's
enough to get the same off_t that GRASS used.
Ultimately, the only place where the actual off_t size is "known" is
in compiled code. It might be worth adding this information to the
output of g.version.
