[GRASS-dev] Vect_rewrite_line using off_t as line id
Martin Landa landa.martin at gmail.com
Fri Sep 18 02:08:56 PDT 2015
2015-09-18 10:29 GMT+02:00 Glynn Clements <glynn at gclements.plus.com>:
> Ultimately, the only place where the actual off_t size is "known" is
> in compiled code. It might be worth adding this information to the
> output of g.version.
I added this info to g.version in r66256.
$ g.version -g
version=7.1.svn
date=2015
revision=66133
build_date=2015-09-18
build_platform=x86_64-unknown-linux-gnu
build_off_t_size=8                                               <---
If it's worth I can backport to relbr70. Martin
Martin Landa
http://geo.fsv.cvut.cz/gwiki/Landa
http://gismentors.cz/mentors/landa
